Old 05-22-2008, 03:44 PM
haylees haylees is offline
just bought a 96 ford windstar and replaced a moduale
i just bought a 96 ford windstar mini van. It has sat for a couple years. I just replaced the module. It cranks but wont fire. It might have bad gas in it. i hope its not the coil pack. Can anyone help me please.
Old 05-22-2008, 05:34 PM
mundy5 mundy5 is offline
Re: just bought a 96 ford windstar and replaced a moduale
what module are you talking about? I would first consider the battery b/4 anything else especially if you say it's been sitting for 2 yrs.
2003 Windstar LX
1998 4dr Civic LX
Old 05-22-2008, 06:03 PM
a fully charged battery has been placed in there. it was the ignition module sorry about that.
Old 05-22-2008, 08:53 PM
well i just put good gas in my 96 ford windstar minivan. so its not that. it will crank and it wants to start. i almost had it started but it died out real quick. so please anyone that can help it would be veryyyyyyyy. nice. thank u haylee
Old 05-22-2008, 09:11 PM
12Ounce 12Ounce is offline
Are you getting fuel to the fuel rail? It's a bit of work, but I would probably drop the tank and swab it out ... replace the inlet sock on the fuel pump ... and replace any fuel filter in the gas line. Then I would remove all injectors and aerosol-spray-clean the inlets and outlets on each one.
I would pull all the plugs for a look-see ... just to see if they are fouled or whatever. Then check to see if you are getting spark.
Of course, you want to pull any codes that may exist. I don't know how to do it on your model ... but it can't be too hard to do.
Make sure you have good clean oil in the engine before you are successful in starting 'r up.
