Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 05-22-2008, 11:48 AM
cooltc2004's Avatar
cooltc2004 cooltc2004 is offline
Send a message via AIM to cooltc2004
1995 Buick Park Ave Electrical - Engine cutting off
Lately my 1995 Buck Park Ave's engine has been cutting out when I hit the brakes. It seems to be somewhat intermittent, though when it does it, it does it often (during that drive). Anyone have anything similar? Any fixes? Any suggestions?
Old 05-22-2008, 03:09 PM
maxwedge maxwedge is offline
A990 racer
Re: 1995 Buick Park Ave Electrical - Engine cutting off
I assume it restarts ok, no mention, if so try cleaning the throttle body and remove and clean the iac for starters.
Old 05-23-2008, 11:43 AM
cooltc2004's Avatar
Yeah, sorry, it does start right back up. I'll give that a try, thanks.
It almost seems like its a ground? I've had problems with that darn ground bar under the drivers side before, is there one of those connected to the brake lights?
Old 05-23-2008, 01:19 PM
A990 racer
Not like the one under the sill plate, but all lamps are, of course, grounded. Hitting the brakes just drops the engine to idle, also check the egr, they have been known to cause this also.
Old 08-31-2008, 03:51 PM
knelson276 knelson276 is offline
I'm no expert but i have read about a simular problem that was caused by a brake booster leaking vacumm. Suppose u could test that by disconnecting the vacumm line from the booster and blocking it off, if you still have the problem then its got to be electrical. I dont recommend driving to test with out the booster, you'll have a very hard time stoping the car. good luck
Old 08-31-2008, 08:58 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Again, some good suggestions here; however, this thread also exceeds our time frame allocated for posting in older threads. Please read our guidelines for Posting in Closed or Outdated Threads-PA
Closed Thread
