Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 05-22-2008, 10:14 AM
DD Blue DD Blue is offline
2001 Fuel Pump Electrical Circuit
My wife calls me and says the Bravada won't start. Turns over vigorously but sounds like it's out of gas. The tank is 3/4 full. She calls back 20 minutes later and says it starts but runs "odd". I tell her to take the car home and I'll take a look at it.
When I get home, I turn the ignition on and listen for the fuel pump. Sounds normal, so I turn it over and it starts right up. I turned the car off and did the same thing twice more. On the third start, the car just shut off about 5 seconds after start. On fourth try, I didn't hear the fuel pump. I haven't heard run it since.
So I check the ECM/fuel pump fuse - looks good. Swaped the horn relay with the fuel pump relay (they're identical). Horn still works so it must not be the relay. I dropped the fuel tank and replaced the fuel pump assembly (not fun at all ). I'm pretty sure hoses and electrical connections were reconnected properly and are undamaged.
I even charged the battery but I don't have fuel pump operation (no noise, no pressure). What now?
Old 05-22-2008, 11:11 AM
brcidd's Avatar
brcidd brcidd is offline
Re: 2001 Fuel Pump Electrical Circuit
check the gray wire at the fuel pump connector.. should read 12v with KOEO (key on engine off) for 2 secs- are connectors burnt?, melted?, good ground? New fuel pump - is it aftermarket?- or an OEM replacement pump? Did you have to splice in any wires? Has new pump ever ran- did you bench check it first?
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 06-10-2008, 04:42 PM
I ran a bypass to the pump using straight battery power. Pump worked. Then I did a continuity check of the ground wire to the pump and then the positive. Both checked out OK. So I hooked everything back up and started the car. No problems since.
The only thing I can figure that I did wrong is that I seated the connector just enough to complete the sending unit/fuel gauge circuit but not enough to get juice (or ground) to the pump.
Old 06-11-2008, 08:44 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Thanks for the update, hope it's fixed for the next several years.
