Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 05-22-2008, 08:10 AM
92talontsiawd 92talontsiawd is offline
Send a message via AIM to 92talontsiawd
transmission problem
its not a car, its a boat. but it has a chevy 350 in it and transmission, and the transmission will go into drive but when you shift it into reverse the engine dies. do you think it would be the tourqe converter or what would it be? any clues would be helpful thanks.
Old 05-22-2008, 08:14 AM
maxwedge maxwedge is offline
A990 racer
Re: transmission problem
There nornally is no TC in a boat drive. Something in the unit is locking up in reverse, not good news.
Old 05-22-2008, 12:46 PM
do u think it might need a whole new tranny?
Old 05-22-2008, 01:43 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Is it a prop drive or a jet drive? If it's a prop, and it's locking up, it could be in the transmission. If it's a jet drive, the jet drive itself might be causing the problem - I am not sure if these are designed to run in reverse.
Does the engine just simply stop, or kinda fade out (as if it's stalling)?
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-22-2008, 02:48 PM
j cAT j cAT is offline
this problem is usually the shift cable binding or the shift cable ignition cutout switch.... when going from fwd to reversre the engine must be cutout when changing directions....this should be seen when observing tach as a sudden drop in rpm when changing from fwd to reverse...what outdrive mercrusier..
Old 05-23-2008, 10:20 PM
Blue Bowtie's Avatar
Registered Offender
Don't jump to too many conclusions. Volvo Penta drives also use small block Chevy engines, and they do not interrupt ignition to shift ranges. They use a friction ring mechanism similar to an Auburn "posi" rear axle to smooth engagement.
Many Berkeley pumps also used SBCs, but the pump only runs in one direction while the thrust reverser plate is simply dropped down over the pump outlet to reverse the direction of the discharge flow.
In any case, it's probably a safe guess that the torque converter is not a problem.
Old 05-24-2008, 11:31 AM
yes i agree that! with the limited info as to exactly what this person owns i guessed that this problem was like my problem and my fellow boaters...
volvo is the best.....smooth operation..
