Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > F-Body Problem Diagnosis
F-Body Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-21-2008, 08:21 PM
Mikei16 Mikei16 is offline
1987 Camaro 2.8 Won't Start
I have a 1987 camaro 2.8 turns over, starts and runs about 10-20 seconds and then dies, (like the old mopars with a bad ballast resistor) it has a new cap-rotor-plugs-coolant sensor and a new distributor, it has 40 + psi fuel pressure. Any idea's. Also no codes
Thanks for any help
Mike
Old 05-23-2008, 09:41 AM
chevyrulespops's Avatar
chevyrulespops chevyrulespops is offline
Re: 1987 Camaro 2.8 Won't Start
it sounds like you might have an electrical problem with a loose or corroded wire going to the distributor, coil or alternator...Check those wires carefully let us know if you were able to fix it please
Old 05-24-2008, 07:12 AM
Thanks I will check it out and get back to you.
Old 06-02-2008, 08:21 PM
Checked the wires, they look good, it might be bad gas!!. It runs ok if we spray carb cleaner in it. The car has been sitting for awhile. I will keep you posted
Old 06-03-2008, 09:28 AM
Well, it seem to have been out of gas or very low! (gauge reads full) Put 5 gal of gas in the tank and replace the gas filter (filter was dirty) The car runs but act like it is starving for gas, got a code of 44, car seem to start better once the engine is warn. You can slowly give gas, very light pedal. Any idea's
Old 06-03-2008, 09:30 AM
New Post
Old 06-03-2008, 11:44 AM
A code 44 is mainly a lean condition caused by either a bad oxygen sensor, carburetor, fuel injector, vacuum leak, low fuel pressure, etc.. It could also be a poor electrical connection, open or short in curcuit, defective map sensor, defective ECM...
I would check the resistance at the fuel injectors to rule those out..I forget what the resistance values should be at or around but compare your readings. On the 2.8 I believe it had a cold start valve assembly to aid in start up as well.
Old 06-03-2008, 03:07 PM
Thanks for the info, I will check them.
