Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 05-21-2008, 08:49 PM
91talondsm 91talondsm is offline
help need decent air map settings for my mods
i no every cars different but i need some decent air map settings for my 91 talon to start with. anyone out there with 550cc injectors on a 14b at around 17psi on a 1g that can help get me close to a good tune.
i read somewere to start the throttle position at 69/70 to tune the lows, there at -10 across the lows on the air map and the highs are -10 to 4500 rpm then go to -8 from 4500rpm on.still getting a hesitation at 5000rpm 3rd gear on at 17psi.
also, i no im off topic but real quick i have a slight high idle at around 1200rpm so my fpr is set around 42psi instead of 38psi.the question is should i still have the fpr at 38psi even with a higher idle? im a newb to all the dsm electronics and the apexi neo is killing me.
550cc's,walbro 255fp,stock 14b at 15psi,palm m130 with mmcd logging software,2 1/2in. down pipe to 3in. exhaust, high flow cat.,2g maf with k&n,custom intake,aftermarket boost guage,mbc,6 bolt with 160 compression. in closet:b16ge3 turbo,rochester 680cc inj.
wish list:wideband,headers,1000cc,e85 conversion,dsm link or map,fmic,20g,272 cams,arp head studs,2600 clutch,lsd,keydriver,. 13sec. daily driver goals.
Old 05-21-2008, 09:02 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: help need decent air map settings for my mods
You get a high idle because of extra air getting into the intake somehow. The ECU compensates for the air by itself. You do NOT need to raise the fuel pressure. Raising your fuel pressure really does not do anything to help lean/richen things up anyways. The ECU tries to get a 14.7 AF mixture when in closed loop mode. So the ECU can add or subtract fuel by +-20%. When you up the fuel pressure the ECU lowers your injector pulse causing the same amount of fuel to go in the motor. All you are doing is letting that value get away from 0% correction.
Say when you upped your fuel pressure that 4psi the ECU is taking out 5% fuel to compensate. Now you only have 15% of fuel left for the ECU to take out instead of 20%.
With bigger injectors you will be running rich so I would set all your setting to 0 or maybe -5% and make a run to see where your AF ratio is first. Make sure you tune with a WBo2. Tune your WOT AF first and then start on your part throttle. The ECU will take out fuel as needed at low throttle but that value may be around -15% or so, so you do want to tune the part throttle after to try and keep your short term fuel trim around 0.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 05-21-2008, 09:36 PM
so high air map set to -5 and make a few passes? i have no wide band or datalogger so i herd to tune each rpm till the o2s arnt moving no more then plus them till they start moving then add 2 more clicks up.thats how it said to tune with a narrow band,got it off a forum at prostreet.com
Old 05-21-2008, 09:43 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Lower your fuel pressure to 37psi(stock 1g). I'm not used to an SAFC but if it has a global fuel setting it should be at -18% to compensate for your injectors. Now that you upped your fuel pressure you would have to change the global to -24% since you are flowing more fuel in the same amount of time.
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 05-21-2008, 10:32 PM
well set the base to 37 at 0 vac. it hits around 50psi at 15 psi of boost, guess il just have to mess with the air maps till it fills right.
its not running rich no black smoke but at high rpm 6500 to 7000 it blew a light bluish grey or white smoke not very noticable and my dipstick poped out,only air thow it didnt spit any oil so i guess a new pvc is coming tomarrow. thanks for the help.
Old 05-21-2008, 10:48 PM
Holset powered 420a
What elevation are you at. When I use to tune off my narrowband I would tune to .98volts. When I dynoed I was at a perfect 11.5 AF. This was around 200ft above sea level. The higher you are the lower voltage you tune for. I dont know about then voltage leveling out or anything. Sounds like BS and I wouldn't do it.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 05-22-2008, 01:37 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Since it hasn't been said...BUY A LOGGER! Narrowband tuning is like cleaing a loaded gun, in the dark, with one hand, sitting on an upside down barstool.
Kris
2012 Genesis Coupe 2.0t
Old 05-22-2008, 07:39 PM
im in arizona. well it seems that when i set my maps to -50 for fun the car wants to die and when i push the gas it wont rev up like its adding to much fuel. so should i be plusing the air maps to add more air or less fuel? i dont get it when its at negative or positive whats it doing?i no its telling the MAS or tricking the mass to think its running less or more air right? so i dont get why when i minus the air maps i smell gas or it smells richer. some1 help thanks
Old 05-22-2008, 08:51 PM
TalonEclipseMixGsx's Avatar
TalonEclipseMixGsx TalonEclipseMixGsx is offline
Don't go hitting any kind of boost with your high throttle set at -50 or say goodbye to that 6-bolt.
When you start to alter the airflow signal you start to pull timing. Spiderturbo had a good writeup in the tech articles about this.
When you subtract on the afc, you are leaning out the AFR's and when you are adding, you are richening up the AFR's
With 550's you should only be subtracting on the AFC, since you are trying to compensate and trick the ECU into thinking your still running the 450s while running more boost.
98 Eclipse GSX-EVO3 16G, BC 272's,ETS FMIC and short route piping,TRE Stage 2 tranny, ACT 2100, Walbro 190lph,550cc jectors,SAFC NEO,GM MAFT, AEM UEGO wideband,ported SBR Exhaust Manifold,O2 Dump,EBay Intake,3" megan downpipe and catback exhaust,TurboXS boost controller,HKS BOV,Ebay Short Shifter,Boost Gauge,Symbroski shift kit & shift cable bushings, RRE catch can
94 Talon 1.8L-SOLD
02 Civic EX- Daily driver (staying stock)
Old 05-22-2008, 09:58 PM
i set my afc to plus 10 across the board on both high and low to see how it would run and it ran fast enough to get a ticket lol,nah it was fast the only thing is is that i had major blow by,it blew my dipstick out with a bunch of oil to. could running rich do that? when i had it on the minus it didnt have that much blow by i literly blew half a quart of oil out.
Old 05-23-2008, 07:48 AM
Buy
A
Logger!
Kris
Old 05-23-2008, 09:50 AM
kjewer1 kjewer1 is offline
AF - Advisor
Here is a good example of when .98 volts does not equal 11.5:1 That log screencap was of a run where I lost the motor.
-15% across the board should be pretty safe but not so rich that you ruin your motor. This assumes you're back to stock base pressure, which is where you want to be. I would recomend running that until you get a logger and/or WBO2.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 05-23-2008, 07:29 PM
a
logger
will
come
next!
and about the -15 across the board is that both high and low map? and should i keep the 69/70 on the t.p or should i set it at 30/80 witch most are cars are suposovly tuned to?
Old 05-23-2008, 08:06 PM
AF - Advisor
The post quality is killing me here...
15% on both high and low. This almost accounts for injector size only and does no tuning at all. With both maps the same, the high low switch over point doesn't matter, but you can set it to a normal value if it makes you feel better. Again, this isn't guaranteed to be correct, so I would still take things easy until you get a logger or WB on it. But if you would trust the car with the stock injectors and no AFC, this will be about the same thing.
Kevin Jewer
Old 05-23-2008, 09:13 PM
sorry bout the post quality here, im a newb. to this and my grammer isnt that great plus im trying to explain things that i no nothing about so bare with me guys please.
now -15 across the board u say will be like running my 450cc injectors again and has no value when it comes to tuning so obviously 15psi should be max right now for those injectors. i forgot to mention i have my lower MAS comb out and the plastic screw out level so should i try like -13 across? will that be safe? i put the MAS mod on my sig. now. highly appreciate the help.
