Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-21-2008, 07:19 PM
deesandvees's Avatar
deesandvees deesandvees is offline
What size exaust pipes and what about h or x pipe?
I'm dropping the car off at the exhaust shop on Saturday and was wondering if somebody can tell me what a h pipe or x pipe does. I'm getting true duals on my '87, headers back. I think the header collector size is 3". I don't want to waste money by having two big of a pipe and don't want to small either. Also I've got Vortec heads on this 383.
Please no responses about legality because I am aware of all the laws. Let me just say I'm an international gentlemen and pleasure seeker and am protected by diplomatic immunity in all ways shapes and sizes
'87 Landau
Old 05-21-2008, 07:32 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: What size exaust pipes and what about h or x pipe?
Why, sure you are. Because you said so.
Use 4" collectors with 1.625" tubes. Keep the exhaust pipe in the 2.5" range and use an H-pipe.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-21-2008, 07:36 PM
What does the h pipe do? 4" collector? So upsize an inch from my 3" header collector?
Mine are Hedman's, something like this:
'87 Landau
Old 05-21-2008, 08:02 PM
beat88ls's Avatar
beat88ls beat88ls is offline
i was always told the X or H pipe will equalize the back pressure. and there are some out there who will tell you if you have an X or H pipe you dont have true dual exhaust... if i did a dual-dual exhaust i would use an X or H pipe...
1997 Jeep Grand Cherokee Laredo 4.0L
2004 Jeep Grand Cherokee Laredo 4.0L
1983 Caprice Classic 5.0L
Old 05-22-2008, 12:57 AM
silicon212's Avatar
Confoundingly Lucid
The H-pipe (or X-pipe) is also referred to as a 'balance pipe' and smooths out the pulses between the cylinder banks, thereby reducing back pressure.
As for the true dual statement, the balance pipe actually increases volume as it potentially gives EACH CYLINDER access to both sides.
The larger collector size will help with bottom-end while retaining the performance at higher RPM.
Old 05-22-2008, 08:43 PM
GreyGoose006 GreyGoose006 is offline
h pipes are inferior to x pipes though because of the sharp angles.
the BEST crossover is one that allows free flow in all directions at once.
i cant find a link, but it was basically an x pipe with a connection between the top and bottom of the x on either side
the best i can manage is this
|\_/|
ignore the dots, they are for spacing
Old 05-22-2008, 11:55 PM
silicon212's Avatar
Confoundingly Lucid
True, an H pipe doesn't perform as well as an X pipe does - but keep in mind that X-pipes or the hybrid that you speak of both require a lot of real estate, increasing the heat production (er, heat release) under the car. Also, remember that each connection on the exhaust system is a potential point of failure. In many views, the gain of the X-pipe over the H-pipe does not outweigh the potential downfalls.
Old 05-23-2008, 05:40 PM
j cAT j cAT is offline
there is a web site that details the correct location of the H pipe... its position is important to achive the maximum effect..
