Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-21-2008, 07:10 PM
deesandvees's Avatar
deesandvees deesandvees is offline
Are the 9C1 center caps supposed to be steel or plastic?
I've seen these for sale as plastic with a sticker. Is there a steel one that's authentic or are these possibly the real thing? I can see cracking the plastic if you overtorque the lugs.
'87 Landau
Old 05-21-2008, 07:30 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Are the 9C1 center caps supposed to be steel or plastic?
None are steel - the center caps you show are actually for truck rally wheels and not the 9C1 wheels (these center caps say "Chevrolet Motor Division" instead of the Bowtie). Of these, the real ones are made of zinc.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 05-22-2008, 02:43 AM
burnM's Avatar
burnM burnM is offline
I don't see a problem with the plastic caps. They are fastened with the three smaller holes directly to the rim, the lugs don't touch them at all. Those look exactly like the metal center caps that I currently have. If they look the same, and they are cheap, RUN 'EM!
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
Old 05-22-2008, 07:57 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
Well, i recently bought some caps for my car. The way they work is that you need these special lug nuts that have threads on the outside. Once you put those on, hold the center cap on, and then there are these black plastic nuts that you hand tighten and thats what holds it on. You shouldn't have to worry about over-tightening either because the lug nuts don't bolt over the plastic. And i do believe these are plastic from the factory, my dad has a chevy express van and he got some silverado rims which have chevy center caps that are plastic from the factory. Everything these days is plastic
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
