Old 05-21-2008, 06:13 PM
1943jgb 1943jgb is offline
91 Stealth es,non turbo
Need Help...
I gave my son a 1991 Stealth ES for graduation....He lives in Texas...I live in North Carolina...........The engine died and will not restart...Only fires on 2 Cyls...Replaced Coil,Ignition module,Cam angle sensor and ECU...Still will not start... I am 1200 miles away from him and I have no reference material to tell him what to do. Could use help PLEASE
Old 05-21-2008, 06:27 PM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
Re: 91 Stealth es,non turbo
Originally Posted by 1943jgb
Need Help...
is the car getting spark on all the plugs? ik you replaced the coil and ignition module but maybe ur plugs or plug wires are bad. does it try to fire or just turn over? do u have proper fuel pressure to all cylinders? have you done a compression test?
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
Old 05-21-2008, 06:38 PM
new2mitsu new2mitsu is offline
have you checked the PTU unit behind the coils?
'93 3000gt VR-4
170k, 27k on JDM motor
MBC @ 14.5 psi
Datalogger
Intake
T-Pros Downpipe
Gutted Pre Cats
Mods to come: Upgraded Fuel System and 75 shot of Nitrous, Full Exhaust and hopefully 15Gs
Audio
Sony Deck
Eclipse 6x8 2 ways in the back
Clarion Kevlar cone Component System in the front
2 Alpine Type S 10 inch DVc Subs
1 Audiobahn 10 inch DVC D Jones Series
One 800 Watt Jensen amp
and a soundstream 300 watt 4 ch to the speakers
And still under 4000 lbs w/ me in the car
Old 05-21-2008, 06:46 PM
he already replaced the PTU..
Old 05-21-2008, 07:00 PM
Ref 91 Stealth...
My son stated that he was driving along when the engine stopped..Was able to restart and get home...He says he and his friends checked the spark and only had spark on (looking at engine from front he says that the first and second plugs would fire and the engine would flood and have small backfire
I told him to check timing but a 19 yoa who is disgusted is hard to deal with.
Old 05-21-2008, 07:06 PM
Ref 91 Stealth...
sounds like plug wires possibly, he replaced the coil and stuff rite? if he is getting fuel but no spark on the cylinders then its gotta be plug wires, did he check the back plugs for spark? make sure all plug wires are in the correct order in the coil pack as well. its kinda rare but not unlikely that the plug wires could go bad like that but if they are old which im assuming they are, thats what i would try.
Old 05-26-2008, 12:22 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
where in TX is your son? there is quite an extensive network of 3000GT/Stealth enthusiasts throughout TX. check out the DFW3S (Dallas-Ft. Worth), NT3S (North Texas), and H3S (Houston) 3S clubs link on 3si.org: http://www.3si.org/forum/f93/
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 05-26-2008, 08:28 PM
Just talked to my son and he says they took each wire from the coil and turned the engine over and that only 2 terminals on coil pack fired,he also said that that the ECU that was taken out and replaced appeared to have aburned capacitor, Right now he is waiting on his friend to return from an out town trip before resuming work. He seems to think his friend knows how to work on cars.We will see.....
