Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 05-20-2008, 08:25 PM
2000oldsilh 2000oldsilh is offline
break problem
I have very soft breaks. Almost right to the floor. When I pump it a few times the pedal gets hard but then looses it's pressure and back to the floor. I bled the system. All the shoes and pads are new. What is going on?
thanks,
Chris
Old 05-20-2008, 08:30 PM
roreed08 roreed08 is offline
Re: break problem
did you make sure all bleaders were tight
Old 05-21-2008, 04:34 AM
Re: break problem
Yes all bleaders are tight. There is plenty of fluid in the system.I read in the manual, that you have to bleed the traction control system first before you bleed breaks. What Im I doing wrong? I did this job on few other cars and I had no problem. Do you think the fluid may be the problem? Thanks.
Old 05-21-2008, 11:34 AM
merc81 merc81 is offline
Re: break problem
thanks,
Chris
If you just rest your foot on the brake pedal, does it gradually sink all the way to the floor? That is the symtom of a bad master cylinder. When it starts to fail, brakes get soft, pedal will sink to the floor in about a minute or less.
Old 05-21-2008, 12:42 PM
rockwood84 rockwood84 is offline
Re: break problem
seals are worn out in the mastercylinder. time for a new one.
Old 05-21-2008, 12:56 PM
Re: break problem
are the wheel cylinders leaking in the rear hubs?
Old 05-21-2008, 02:12 PM
Re: break problem
No there is no leak at all anywhere.
Old 05-29-2008, 05:33 PM
gls02 gls02 is offline
Re: break problem
When you bleed the brakes you have to start with the wheel furthest from the master cyclinder, the right rear wheel. Then bleed the left rear, right front and then the left front. If this doesn't work then I too believe that your master cylinder is bad.
Old 05-30-2008, 04:24 AM
Re: break problem
I changed master cylinder, put new fluid and bled the breaks. That finaly solved the problem. Now breaks work just fine. Thank you all very much for your input to fix my van.
