Old 05-20-2008, 09:10 PM
Turbokid15's Avatar
Turbokid15 Turbokid15 is offline
90 Accord No start
Alright don't know where to begin. Picked up the car for a friend and the car will not start. The fuel pump will not come on. Is there a fuel pump cutoff switch on this car and where is the relay.
TIA Nolan.
The truck
07 F-350 CC Dually Stroked
Old 05-20-2008, 09:37 PM
roreed08 roreed08 is offline
Re: 90 Accord No start
is it turning over its either air, fuel orspark thats the only reasons it can be see if its getting spark then pull a spark plug out stick your finger over the hole and if it blows away on the compression storke you have compression check those and there is no fuel pump shut off
Old 05-20-2008, 10:10 PM
andrea143 andrea143 is offline
TIA Nolan.
look under drivers side dash there is a main relay beside steering column next to the cruise control box(silver box)
Old 05-21-2008, 06:18 PM
Turbokid15's Avatar
Ok got the main relay out. Is there a way to test it before I go buy a new one.
The truck
Old 05-22-2008, 02:56 PM
mpumas mpumas is offline
The problerms experienced with the main relay involved bad solder joints on the printed circuit board. A close examination will show small breakes around where the relay pins attach to the board. So one fix is to reheat all those joints until the solder melts and then let it set up. I have not heard of bad coils or bad relay contacts. The coils are 12 volt and can be tested woth am ohm meter or 12 volts across the coil to see if it activates.
Old 05-22-2008, 06:09 PM
Turbokid15's Avatar
Little update. I found out it is not the pump. We dropped the tank and hooked directly to the pump + and - success. So I guess I am limited to the relay.
The truck
Old 05-23-2008, 01:50 AM
Before you start buying parts, I suggest you do some testing. It could be something else. Check your ignition/spark, your timing belt by looking to see if the cam is turning when you turn the engine, etc. Check the fuel pressure. I have never heard the fuel pump run from inside the car so it might be running after all. Most often the reason the car won't start is ignition related (coil voltage, coil, igniter, main relay, etc.) . The next reason is fuel related which could be the fuel pump, fuel filter, injectors etc)
Old 05-26-2008, 04:37 PM
Turbokid15's Avatar
Found out it is the ignitor coil that has a hole blown in it.
The truck
Old 05-26-2008, 11:27 PM
damdash damdash is offline
ok i have been having basically the same problem. While messing with the alarm my car just shut off on me. I have ruled out the alarm as the culprit since it unhooked completely and the fact the car has been sitting for the last ten months(wrecked). I tried starter fluid in the intake and checked the fuel pump. I was checking for the main relay but am not sure what it looks like. This is the closest thing i found that could it. If i am wrong can someone please post a pic of it. Also where is the igniter located?
Old 05-27-2008, 06:48 AM
Turbokid15's Avatar
Can't help you out on what that is but the ignitor coil is in the distributor cap. Now for another problem I found while changing spark plugs all but one looked normal. The second plug from the front of the motor had a look of baked on oil on it. I thought Ill do a compression check to see what is going on. Results are first cylinder: 210 Second cylinder: 0 Third cylinder: 85 and Fourth cylinder: 190. I am not to worried about number 1 and 4 as I am about 2 and 3. I know something is wrong with number 2 for sure. Could I have a blown head gasket of is something wrong with the head itself.
The truck
Old 05-28-2008, 04:35 PM
Turbokid15's Avatar
Does anybody know what could be causing the distributor to not spark. I changed the coil and it did nothing.
The truck
Old 05-28-2008, 08:06 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Dumb question, but the timing belt is turning the cam and distributor, yes?
You'll get weird compression readings and no spark if the cam is not moving...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 05-28-2008, 08:28 PM
Turbokid15's Avatar
Took the valve cover off and the cam is moving. I am thinking about just gettin a new distributor. I guess there is something wrong with the distributor. I am also thinking about the head gasket being the problem with the compression. I have heard it is a common problem on these cars.
The truck
Old 05-28-2008, 08:37 PM
Dizzy wasn't red/brown inside, was it? Does the rotor move?
A number of Hondas in the 90's had problems with a lower bearing in the diz that would start rusting and powder the inside of it before breaking, then it won't turn anymore...
...empty gun rack.
Old 05-28-2008, 08:40 PM
Yeah kinda sounds like there's a blowout between 2 and 3.
Or the timing belt snapped before and bent valves in two and three when they hit TDC...at any rate, sounds like a lotta work. Hope that car was cheap...
...empty gun rack.
