Old 05-19-2008, 09:20 PM
readallen readallen is offline
o2 sensor
my car has a single wire , have old one with wire ripped out, took the metal crimped thing off, can the wire touch the center metal tube or not?
Old 05-19-2008, 11:23 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: o2 sensor
Its a bad idea to crimp the o2 to the shielding of the wire. That part is grounded to the chassis so youd essentially be shorting out the o2 sensor and it wouldnt work at all.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 05-20-2008, 12:28 AM
Re: o2 sensor
I'm 96% sure it can be
Old 05-21-2008, 12:20 AM
FrodoGT's Avatar
Re: o2 sensor
WTF is the rest of that? your o2 sensor? If it is then no it cannot touch. The entire casing of you o2 is attached to the exhaust, which it uses as a ground. The o2 puts out a positive voltage to the ecu of between 0 and 1 volt. If that thing touches itll just run straight to ground and not only never show the ecu voltage..itll just burn up the o2.
Current project:
Rio Red 91 hatch.
Old 05-21-2008, 06:13 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: o2 sensor
Actually, that area that he's pointing to is part of the sensor that's isolated... it's where the wire gets crimped to inside the sensor. After it's crimped, there is a black plastic housing that goes around the wire to isolate it from touching the outer housing of the O2, to prevent what Frodo was talking about.
For the trouble, it's not even worth it to bother though... just get a new O2 sensor from a junkyard, they'll probably tell you not to worry about paying for it.
Old 05-22-2008, 05:54 PM
it worked and a code 16 question
well, i soldered on a new wire to the 1/8" strands of the old wire that was pulled out, pull the sensor in my car , and it worked , or at least it not pulling the code anymore, and i double checked it with a multi meter and it is isolated from the rest of the sensor. i could see were it was crimped but i was not sure if the insulation on the wire went down in further than that point.
Another Question--- would a low battery make the ecu put code 16(fuel injector) when starting the engine? if not what is the usual problems associated with the code? thanks
Old 05-22-2008, 06:35 PM
Re: o2 sensor
faulty connection or faulty injector are usually the only reasons that will show.
