Old 05-19-2008, 09:29 PM
jcurry05 jcurry05 is offline
Stalling problem(possible crankshaft position sensor)
Hello I have a 2000 GP with the 3800 series II with 139000 miles and it now stalls out after I start it almost immidiatley. Sometimes I can hurry up and hit the gas and keep it reving at about 2000 to 3000 rpms for like 10 seconds and it will be fine after but now I cant at all. It does seem to work when i start it and then immediatley shift to reverse or drive but im not tryin to do that every time. I replaces the mass air floe sensor about a year ago and I disconnected it to see if that was the problem but it wasn't. I also cleaned the idle air controller with some carb cleaner spray so thats not the problem. I only other thing I can thjink of is that it has something to do with the crankshaft postion sensor. Before my car was doing the thing were the tac stops working and the Trac off light comes on and I was told that it was the crankshaft position sensor so I already bought one I just haven't had it installed yet so could that have something to do with the stalling problem? Thanks
Old 05-20-2008, 07:57 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Stalling problem(possible crankshaft position sensor)
Absolutely. Since you have it get it replaced.
Timeslip 08/12/06
AF Community Guidelines
Old 05-21-2008, 01:58 PM
Ok so I got my Crank shaft position sensor installed but its still doing the same thing and I am all out of ideas. does anyone know what this could be?
Old 05-22-2008, 04:53 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
check the wiring harness to the CKPS. It may be corroded or worn through.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 05-22-2008, 07:03 PM
michtom michtom is offline
When you changed the crank sesor, did you perform the CKP System Variation Learn Procedure? If not, this can only be done with a qualified tool, such as a Tech 2.
Old 05-24-2008, 05:48 PM
Thanks for the response. Where is this wireing harness to the CKPS?
Old 05-24-2008, 05:49 PM
Im not sure if they did that or not. I didnt install it myself I got a mechanic to do it.
