Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 05-19-2008, 07:38 PM
dunndeal55 dunndeal55 is offline
Mass Air Flow Sensor Hums
Good afternoon,
I have a 2000 Explorer and my Mass Air Flow Sensor is making a humming sound. I can disconnect it from the air intake hose and the sound stops and then I can reconnect it and the noise starts again. Have replaced the sensor and the noise went away for a couple of hours but returned again.
Any ideas??????
Thanks in advance,
Charlie
Old 05-19-2008, 09:49 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Mass Air Flow Sensor Hums
Is the sound an electrical sound, or is it due to air passing through it? Does the sound change with engine speed? What happens to the sound if you just unplug the electrical connector from the MAF sensor? Of course unplugging (and removing) the MAF will likely set codes, but at least you'll know why they are there.
-Rod
Old 05-21-2008, 06:36 PM
mab6680 mab6680 is offline
i had this same problem with my 2000 explorer it was the iac sensor it cost me like 50 bucks from auto zone and took like 5 minutes to change i hope this helps
Old 05-22-2008, 09:03 AM
Thank you mab6680 and shorod for the input, we will be checking things out this weekend and will report back.
Thanks again,
Charlie
