Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 05-19-2008, 01:40 PM
florida thomas florida thomas is offline
1996 tranny crazy
my 1996 yukon sometimes or almost always slips out of reverse the first time i put it in gear, but if i go to p or n then back to rev its okay fot this time but it does it again after that. drive gears are okay, any ideas
Old 05-20-2008, 01:00 AM
2000CAYukon 2000CAYukon is offline
Re: 1996 tranny crazy
When the 4L60E is put in Reverse, the lo-reverse clutch is applied and the reverse input clutch is applied. A problem with either of these clutches could be a fluid pressure issue or worn clutches.
You can test the lo-reverse clutch by putting the tranny in 1st gear and get the speed upto around 30 and let off the throttle. If the lo-reverse clutches are good, the engine should brake hard the truck should slow down quickly. If it feels like neutral, the lo-reverse clutches are gone and a rebuild is necessary.
Other possibilities are:
worn/cracked piston seal (lo-reverse or reverse input)
sticking lo-overrun valve
reverse input clutches
valve body
sun shell (when it goes, no 2nd, 4th or Reverse)
//2000CAYukon
