Go Back   Automotive Forums Car Chat > Buick > Skylark
Old 05-19-2008, 12:37 PM
almagg almagg is offline
Coolant loss
1997 Buick Skylark V6 3.1ltr
I am losing about half a tank of coolant a week.
A couple years ago my heater core went and I had them bypass it.
Since I am in Florida it was not that necessary.
Now can there still be a leak associated with heater hoses even though it was bypassed?
It is happening on the passenger side. Now I know that I have a manifold gasket leak, but from what I am seeing and the location of the drips I don't see the manifold as the immediate problem. Water pump is okay. The problem is when I got under there I can't see anything because of the body plates.
Obviously I will have to take the plate off but wanted to find out about any possivle heater connection.
Old 05-27-2008, 09:06 PM
Scotty89's Avatar
Scotty89 Scotty89 is offline
Re: Coolant loss
If you want to make sure its not the heater core just check the connection where they bypassed it. If its dry then i wouldnt worry about it. If your car emits white smoke then it may be burning coolant. Since you know you have a manifold leak i would deal with that first before it gets worse.
