Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 2nd Gen 00-05
Old 05-19-2008, 12:34 PM
brack2 brack2 is offline
01 motor swap
What engines are a direct fit into a 01 neon es SOHC? Ive been told only a 01 or 02. Why wont the newer ones fit in?
Skip
Old 05-20-2008, 10:17 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: 01 motor swap
You can use the 03-05 engine, but they have a newer NGC PCM which you don't want to use.
You can use any engine from 00-02 without any other problems.
2003 Dodge SRT-4
Old 05-20-2008, 10:37 AM
Re: 01 motor swap
so is everything a direct fit in? Do I need to reuse my fuel injection setup? I know alot about the ford 5.0 and not much about neons. the engines on ebay for the 04 05 look identical. are the bolt patterns for the bellhousing the same? accessories? motor mounts? What do I need to do to not have to use the PCM for the newer motor?
