Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 05-19-2008, 03:17 AM
NightRider88 NightRider88 is offline
S15 V8 Swap Drivetrain
I have an '88 S15 with a 2.5L 5 spd, I am going to be swapping the engine for a 305/350 soon and i was wondering if it is possible to put a half ton diff in the rear and if there is enough room underneath for the standard tranny that comes with the motor?
Old 05-19-2008, 07:42 AM
DAB77 DAB77 is offline
Re: S15 V8 Swap Drivetrain
The engine and trans won't be a problem. Never tried swapping rear ends but anything is possible.might have to cut the tubes and shorten the axles.
Old 05-19-2008, 10:56 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
There are kits availible with V8 swap motor mounts, headers, exc. Use at least a 350 to make the swap worth while. I would use a T-5 trans if you plan on staying with a stick shift and are using a mild V8 unless you plan on swapping to an automatic. Yes, an 8.5in 10bolt from a half ton can be used but it has to be narrowed. Try finding one from a ZR2 as they use a narrowed 8.5in 10 bolt from the factory that had 3.73 gears and a limited slip.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
