Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 05-18-2008, 07:16 PM
dtown_wizard dtown_wizard is offline
Ac Compressor Question
HELLO I HAVE A QUICK QUESTION ABOUT A COMPRESSOR, MY 98 MONTE CARLO NEEDS A NEW COMPRESSOR AND I AM GOING TO BUY A NEW ONE BUT DOSE IT COME WITH OIL ALREADY IN IT OR DO I HAVE TO ADD IT MY SELF AND IF SO HOW DO I DO THAT.
Old 05-20-2008, 11:45 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Ac Compressor Question
Pleas type in the lower class.
Upper class is considered shouting hurts my eyes and ears to read it..
Make sure that new one is brand new not rebuilt.
Always check and drain compresser if it has any oil in it.
Rule of thumb is 2 oz oil for compresser and if system has leaked any oil add a little more oil for leakage.
Also 2 oz for the reciever /dryer when replacing.
But I would not go over 3- ozs for compresser and 2 for reciever dryer .
Use pag 150 ac oil.
MT
Old 05-20-2008, 07:40 PM
j cAT j cAT is offline
prior to adding r134 refrigerant you must pump out all air from system...this may take a few hours as the oil must boil off the air it contains...you can recharge your system without doing this but risk damaging your new 500.oo compressor...as pag oil and air/moisture create acids....
Old 05-20-2008, 09:08 PM
brcidd's Avatar
brcidd brcidd is offline
Just curious-- why do you need a new pump?-- those V-5 compressors are pretty darn durable- but have a tendancy to leak at the body o-rings- and shaft seal-- both which are replaceable...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 05-22-2008, 03:26 PM
on this vehicle the plastic shoud is removed or damaged when the oil filter is serviced this then exposes the a/c compressor to road salts/water which then causes the pulley bearing to fail...
