Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 05-18-2008, 02:10 PM
evildragon evildragon is offline
URGENT: Water pump removal
I can't get my water pump off to replace my optispark.
I removed the secondary air pump, and unbolted the bracket, but the bracket just won't come off.
Please help! I need to be able to drive to work tomorrow.
My one and only car!
1994 Chevy Caprice Classic LS
L99 Engine
Old 05-18-2008, 06:18 PM
Re: URGENT: Water pump removal
nice to know urgent doesn't mean anything..
i finally figured it out. but now i got another problem, after putting everything together, it's not sucking in the coolant.. the reseviore is quite full, but it's just sitting there, the level is not going down, and the engine is overheating..
L99 Engine
Old 05-19-2008, 10:50 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Sounds like now you have an urgent problem
Old 05-19-2008, 11:15 PM
flipflip530 flipflip530 is offline
you might have an air lock in the cooling system. What can happen is air bubbles can get in there and create a 'lock' making the water unable to pass through. You can typically take care of this by filling the highest point of the engine with water. For example, on my girlfriends POS ford taurus, I can take the upper radiator hose off and poor water into the top of the engine. I dont know a whole lot about cars, but thats my two cents! Good luck!
Old 05-20-2008, 08:31 AM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
It's not a matter of urgent meaning anything, it's a matter of people who know something seeing it in time. It does sound like you have a bubble stuck in the system somewhere. I don't know too much about the LT1's but if there's a bleeder valve, open it up and let the air out that way. If not, try what flipflip530 said.
Old 05-20-2008, 12:01 PM
j cAT j cAT is offline
when i replace coolant on lt1 engine i remove the knock sensors this dumps all coolant from the system... on refilling you must fill at thermostat, then install thermostat, then use hose to radiator to complete filling... then run engine to point where thermostat is at temp and with a cloth and other material to catch drips open bleeder on goose neck...don't spill on distributor....this has worked and also keep cap off reservoir so air can escape until this is all competed....before starting something you have never done, it is best to ask how to, before disabling your ride....
Old 05-20-2008, 10:49 PM
By the morning, the coolant actually "settled in". Today, while driving it stayed cool, but every fast acceleration (I love tearing up the streets now, that my new opti is working great, though that pathetic backfire still exists), the low coolant level flashes. So I must need more in it..
L99 Engine
Old 05-21-2008, 12:57 AM
burnM's Avatar
burnM burnM is offline
Bleed the system.. Don't run it like that, you're asking for trouble.
1977 GMC Jimmy - daily driver-sitting on 33's and bedliner inside and out
1995 9C1 Caprice - winter beater
1994 Impala SS - newest project
1991 9C1 Caprice - (rip)
"There are two great problems in the world today; an ever-growing lack of common sense, and too many warning labels. Take away all of the warning labels and the problem will work itself out..." -B
