Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 05-18-2008, 11:01 AM
Bostena Bostena is offline
06 Monte won't shift out of park.....
Monte Carlo stuck in park. Cannot identify an overide solution. Dealer stated there should be a 'hole' to put a pin in to manually overide and allow shifter to move into gear. 3 of us have looked and can find nothing. Car is stuck in garage. Any ideas?
Old 05-20-2008, 11:55 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 06 Monte won't shift out of park.....
Check fuses and try turning the steering wheel while holding down on brake.
MT
Old 05-23-2008, 10:58 PM
dave_1976 dave_1976 is offline
Probably a problem with the shift interlock. Sometimes you can unplug it or you may need to remove it. Should be located in the column.
