| Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here. |
6 bolt wont start help!@!!
hey guys i got everything done and i went to start it up it cranked then fired the rpm went to 1100 like its has to. i let go of the key and it dies i cant keep it runing its a 99 gsx basically stock. i have a 90 cas on it. i lined up the timing marks on the engine and on the cas but that didnt help. it wants to start but cant. i have spark fuel n compression.
Re: 6 bolt wont start help!@!!
Check your TPS to make sure it's aligned correctly, Test your ISC & make sure your throttle bracket plate has the correct tension, Timming is 5deg
Most likely one of those..
DSM geek |
how do i aligne it
www.vfaq.com will show you how.
DSM geek |
i aligned the tps i use a code reader to measure it at full close it reads 0.0 when runing the car it reads 0.3. now it ildes but if i give it gas it will stall out. but if i give it slowly it will start to rev up. but some times if lower the 2k i hit the gas it will stall.
Did you set base ignition timing? This is the only thing big enough to cause a problem like this. Or using upgraded injectors without DSMlink/AFC/etc to compensate for them.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
no i didnt hahah how do i do that lol but im getting the timing light tommarow then.
ok so just to be check i redid my timing and my cousin helped me do it right cuz hes a machinic and he helped me we did it and still the thing has no throtal response could it be my coil. any idies any one please help me out
i still got nothing i changed the fuel filter but still noting heres a video of the rpms View My Video
