Old 05-17-2008, 05:58 PM
ronjon_4's Avatar
ronjon_4 ronjon_4 is offline
94 Grand Prix all of a sudden wont start
I have had this car for a little while and it sits in the driveway. I start it up once a week and take it out. I went to start it today and as it was about to start i stopped the ignition thinking it was going to catch as it almost started but stopped. So when I went to start it a second time it was just constantly turn over and never actually start. Sounds like it was flooded which i thought was weird. Waited a little while and still wont start. Never had this problem before. Ideas?
Old 05-18-2008, 09:44 AM
rickisrad rickisrad is offline
Re: 94 Grand Prix all of a sudden wont start
spray starting fluid in the throttle and see if it starts. If it starts for a second then you can narrow it down to a fuel issue. check the fuel pump relays/fuses to see if they are good. I would also make sure you have good gas in it, if it is really old gas that will also pose a problem .
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
Old 05-19-2008, 06:49 PM
ronjon_4's Avatar
im hoping its just some bad gas or something. seems weird though
Old 05-20-2008, 10:22 AM
I would grab about 2+ gallons of the 91-93 octane or and add the small bottle of Lucas fuel additive in there and see if that helps. The additive will act as a fuel stabilizer and should help the bad fuel, if that is the issue.
Old 05-24-2008, 01:12 PM
ronjon_4's Avatar
put about 5 gallons in with some dry gas with no effect. I did however spray starter fluid into the intake and it starts right up but then dies after a couple secs like you said. Going to try and change the fuel filter hopefully thats just clogged up. checked the fuses to see if any are bad and all look fine. a little dusty but all of them are intact.
Old 05-25-2008, 08:59 PM
ronjon_4's Avatar
any idea where the fuel pump is on this 94. I hope its not in the tank! I replaced fuel filter and checked relays and fuses all fine and no change. So now its the fuel pump but not sure where its at.
Old 05-25-2008, 09:33 PM
inafogg inafogg is offline
sorry man,its in the tank
Old 05-26-2008, 02:31 PM
ronjon_4's Avatar
sonofva!!! well that should be some good times then. Next step is how to get it out
Old 06-02-2008, 09:29 PM
ronjon_4's Avatar
well that was a whole lotta fun. but it worked and hopefully that will be it for a while. Thanks for the help
Old 06-02-2008, 09:43 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
got it going? It was the pump huh?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 06-11-2008, 10:13 PM
ronjon_4's Avatar
indeed. what a pain mostly getting that thing back up in there with just me. The gas gauge sometimes jumps to full and then back to where its really at but that was happening before I took the tank out. But its running and lookin fine. Thanks for the help
