Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 03-05-2003, 03:03 PM
almondeyez1's Avatar
almondeyez1 almondeyez1 is offline
Send a message via ICQ to almondeyez1 Send a message via AIM to almondeyez1
Question Just checkin ....
I just put on 16's on my 95 Civic and this guy told me that it would've been "safer" had I gotten 15's because the wieght of the rims would cause tension on my CV joints/boots later on...is this true?
Old 03-05-2003, 06:48 PM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Re: Just checkin ....
I haven't heard of this being a problem on Hondas, but it could be true, I'm not quite sure. But unless you're rolling some heavy as heck bling bling rims, you should be fine, most "16's won't weigh much over 20 pounds.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 03-05-2003, 10:11 PM
Dezoris Dezoris is offline
Mod for life
Send a message via AIM to Dezoris
The weight of the rims have nothing to do with CV joint wear.
If we applied the same mentality having a 15" lighter rim could cause damage too because it is less rotational mass and it is easy for the drive train to power the wheels which means faster initial rotation bla bla bla, which can lead to wear.
Nope unfounded you are ok.
15"s would only be better from an actual weight perspective, less unsprung weight/rotational mass usually equals quicker initial acceleration.
Now if you lowered the car 2-5" you would see a change in angle of your half shafts, and more tension on the CV boots which may cause premature wear, which could lead to more stress on the joints etc.
M.Sanew - AutomotiveArticles.com
Old 03-05-2003, 11:02 PM
Talking
THANKS!! I just wanted to make sure since I'm still learning the modification process!!! =) :flash:
