Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 05-17-2008, 04:36 PM
jrbueiz jrbueiz is offline
Brakes.
For you guys with 99 & below body style Tahoes; not sure about the later models, when you go to change your brake pads and rotors.....
....specifically when you remove your brake caliper does your rotor flop round; is there nothing that is supposed to keep the rotor in place? C-clips maybe?
1999 Chevy Tahoe LT 4x4 - 4 Door
5.7L 350cid V8 FI (R)
Old/Heritage Body Style
Old 05-23-2008, 05:20 PM
j cAT j cAT is offline
Re: Brakes.
this is normal and preferred as if they did not flop around it would be seized to axle...remove rotor wire brush off rust, then brush on anti seize to mating surface , and install rotor on axle..
Old 05-25-2008, 06:59 PM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Re: Brakes.
YIKES...THE ROTOR FLOPS AROUND WHEN THE WHEEL IS TAKEN OFF
Sounds like a possible recall
Just kidding...normal...the wheel when properly torqued will hold the rotor in place
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 05-26-2008, 05:05 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Brakes.
In the case of floppie rotors I always take a old style lug both and flip it over and zip it on a lug bolt.
Takes the flop out of them while you are working on then,
But be sure to remove it before installing the wheel or you will have a floppie tire and wheel.
MT
MT
