Old 05-17-2008, 12:38 PM
kappy1 kappy1 is offline
P0410 code 05 ls
I just bought an 05 Ls the engine light came on, has been on.
I know the code is secondary air injection fault, first thing I did was change the air filter wow was it bad, just boguht from a dealer too.
I thought maybe this would fix it, did not, Now the housing where the air flow
goes in I heard there is some spray you can buy to clean the screen or element in there, Just wondering if I am on the right track here.
probable causes are 1)relay defective or fuse open
2) check connector and wiring
3) air pump defective or hose block
Is this something the dealer should be resposible for I bought no extended warrenty, but have 60 days thanks for any input Kappy
Old 05-17-2008, 12:52 PM
Re: P0410 code 05 ls
I did some searching and found the same question, i am going to try a few things, with the couple replies, any other info will help thanks
Old 05-17-2008, 04:16 PM
maxwedge maxwedge is offline
A990 racer
410 refers to the AIR system the pump is under the l/s of the ft floor below the dr.'s seat, there is a check valve in the line that can go bad or the pump is bad or the fuse is blown.
Old 05-18-2008, 10:26 AM
brian 1 brian 1 is offline
you have to check the operation of the air check valve,very common for these to get water and moisture in them,preventing operation.if there is nothing wrong with the check valve here is a bulletin to check.Subject:Repeat SES Light due to a P0410 DTC - Possible O2 Sensor
Models:2004-2005 Buick Rainier
2004-2005 Chevrolet TrailBlazer
2004-2005 GMC Envoy
2004 Oldsmobile Bravada
2005 Saab 9-7x
with 4.2L Engine (VIN S - RPO LL8)
Currently, the SI diagnostics do not mention the position 1 O2 sensor as a potential cause of a P0410 DTCIf the SI diagnostics do not isolate the cause of a P0410 DTC, there is no sign of dirt or water in the AIR pump or relay, and proper AIR check valve operation is noted, replace the position 1 O2 sensor.
Old 05-18-2008, 03:00 PM
A990 racer
Good info here, brian 1, I thought the preliminary checks were in order for a 'dyer".
Old 05-19-2008, 04:56 AM
ok thanks I checked fuses do not see any blown, guess its onto the pump or check valve, seams like O2 sensors are common, my old blazer same thing
also that egr valve got stuck alot,, wonder why the 02 does not show
up with the code
Old 05-30-2008, 01:54 PM
mendori1 mendori1 is offline
Ok thanks on the info, I still need some help.
I have replaced both relays and I don't have a blown fuse, Checked the air pump that works.
Now where would the check valve be located?
Old 05-30-2008, 03:09 PM
A990 racer
In the line from the pump.
Old 06-02-2008, 06:10 AM
ff-racer ff-racer is offline
I had to replace my valve recently. It is on the passenger side located on the top part of the manifold. Mine is the L6 engine.
Old 07-16-2009, 07:56 PM
072 072 is offline
Can anyone give the fuse name and location in the fuse block on the fender well and what is the amperage? Am I in the right section to ask this question?
Old 07-16-2009, 08:02 PM
072 072 is offline
I have power or 12v feeding one of the ten guage wires at the relay but the pump does not run. Does this mean the fuse is good?
Old 07-17-2009, 04:01 PM
A990 racer
The pump will only run when commanded by the pcm. If you have power at the the relay the fuse is good, a bi-diectional scanner can command the pump on, to verify its working, the usual issue with these is a rusted/ frozen check valve/solenoid in the line. BTW you tagged on to an old thread, start a new one in the future.
Old 07-19-2009, 12:02 PM
072 072 is offline
Smile Re: P0410 code 05 ls
Thank you for the solid info! I am told this may be under manufacturers warranty. This is a 2005 with 43,000 miles and has been garage kept for the last 4 years. This is descrbed in the warranty section but I am told there is now federal law over-riding the manufactureres warranty? I have to call them monday and find out the real story. Thanks again for your help. I am still trying to navigate the website so bear with me. I am really happy about the quality of Knowledge and that it is free to people who need help. I have just gone back to work after a 2 month layoff etc. etc. etc.
Last edited by 072; 07-19-2009 at 12:09 PM. Reason: Learning how to navigate as I am new at this!
