Old 05-16-2008, 07:59 PM
hoopdawg hoopdawg is offline
90 s-10
any one have a wiring diagram ???
got truck and some one has cut ignition wires on steering column and need to figure oout how to wire it back
Old 05-16-2008, 09:06 PM
old_master's Avatar
Advisor/Moderator
Re: 90 s-10
Autozone has wiring diagrams for most vehicles on their website. Enter the year, make, model, and engine and you'll find it in the repair info section. Don't count on Chilton or Haynes manuals helping you out, they're good for how to's on oil changes.... sometimes
Old 05-17-2008, 07:04 AM
Re: 90 s-10
cant seem to find what im looking for ,,, need wiring diagram from the key switch back to the battery
Old 05-17-2008, 07:16 AM
old_master's Avatar
Advisor/Moderator
Re: 90 s-10
Is this a pick up or Blazer and what engine?
Old 05-17-2008, 01:17 PM
Re: 90 s-10
it is a 1990 chevy s-10 pick up 2wd and has the 2.5 l engine
two items in question one blue one black and the wires have been spiced into but i think theses should be plugged into something so the new key switch that i got will work
would post pic but i geuss i cant
Old 05-17-2008, 08:12 PM
old_master's Avatar
Advisor/Moderator
Re: 90 s-10
Click on this:
http://www.oplin.org/databases/proxy...%2fframerq.asp
type in 123456789 and click submit. Select Cincinnati & Hamilton county and submit, then click on auto repair reference center. Enter year make model etc etc and choose a catagory.
Old 05-18-2008, 05:23 PM
Re: 90 s-10
any way for me to attach pics so u can see what im talking about ????
Old 05-18-2008, 05:44 PM
Re: 90 s-10
figured it out... these are the connectors that have been spliced into and was wondering if they can be identified ??
Old 05-18-2008, 05:48 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 90 s-10
Look again on the auto zone site.
I found this.
http://www.autozone.com/addVehicleId...00c152800bf48b
Go deeper and go to repair info and wiring digarams.
go to chassis electrical and then to wiring diagrams.
MT
Old 05-18-2008, 06:26 PM
Re: 90 s-10
nice pics but when i click on them to make image bigger /// all i get is a red x
Old 06-01-2008, 04:45 AM
dongurinoseikurabe dongurinoseikurabe is offline
Re: 90 s-10
those are your two ignition switch connectors the switch should be mounted on the top of the steering column judging from your pictures id say its ugly under that dash. anyway those plugs should be attached to your ignition switch. im really curious to know just what they were thinking with all the butchery going on there.
Old 06-01-2008, 04:51 AM
Re: 90 s-10
oh and you should note the small tab on the blue connector at its base, the blue connector should be attached to your ignition switch first and then the black one or youll fight it all day.
