Old 05-16-2008, 10:34 AM
jackfoxx jackfoxx is offline
94 Le Sabre Trans problem
Over the last few weeks I have noticed that occasionally (4-5 times) that I get in, start the car, let it warm for 30 seconds, put it in drive, step on the gas and the engine revs but the car doesnt move.I run it through all the gears and nothing, no movement. Let it idle for another 30 seconds or so and feel a slight clunk and then the car will move. Talked with a mechanic about it and he felt that the fluid was draining out of the converter and it needed time for the pump to fill it back up. Ok Maybe...
Yesterday I am getting off of the freeway and come to a stop at the end of the offramp, I step on the gas and the rpm's shoot up and no movement of the car. I rev it again, feel the clunk, and off I go. Same thing happened today.
Trans was serviced about 4 months ago, fluid level good and color good.
I too get the trans shudder on takeoff as well.
This car was great until at about 95,000 miles, I started having multiple issues. Car now has 121,000 miles.
Items replaced in the last 2 years:
ECM/PCM
Crankshaft Sensor
Camshaft Sensor
TPS
O2 Sensor
Motor Mounts
Plugs/Wires
Thanks in advance.
Jack
Old 05-17-2008, 06:24 AM
GringoPete's Avatar
GringoPete GringoPete is offline
Re: 94 Le Sabre Trans problem
ECM/PCM
Crankshaft Sensor
Camshaft Sensor
TPS
O2 Sensor
Motor Mounts
Plugs/Wires
Thanks in advance.
Jack
When you get the shudder does the front end of your car bounce up and down?
Old 05-17-2008, 11:52 AM
Not really a bounce up and down, just more like when releasing the clutch on a manual trans and not giving enough gas, just a little shudder that goes away with more accelerator pedal.
Jack
