Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Brakes and Suspension
Old 05-16-2008, 10:55 AM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
suspension knuckles
so, as most of you know, i'm getting ready to lower my DSM, i have everything now, it will be on Eibach springs, and tokico illumina shocks... now i only want to take the car in to get aligned once... BUT! i need to replace the suspension knuckles in the front to accout for my brembo brakes... my question is, can i lower the car, get the alignment, then remove the knuckles some time later and replace them with the new ones, and my alignment be perfect? or should i wait to do the suspension untill i have everything i need to lower and install the brakes and just do everything at once?
thanks!
Old 05-16-2008, 01:36 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Re: suspension knuckles
Well it would be best to align it after you get it how you want it. But yeah you can go ahead and lower it and align it, then put the knuckles on without realigning it. Because since the knuckles are going to keep the suspension geometry the same since its not lowering the car anymore than before, it won't throw it out of alignment any.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 05-17-2008, 09:04 AM
Black99GST's Avatar
so it will have no effect on the toe or anything? i'm going to lower it and drive it to the shop on OEM rim/tires, i dont want any extra wear on my 20k mile $$$$ tires you know, i guess i could drive it out of alignement untill i install the brakes, then slap on the new tires, and drive straight to the shop...
Old 05-18-2008, 01:15 AM
As long as the knuckles that you will eventually swap to are the same (except for the brake stuff of course) then you will be fine to go ahead and get it aligned now and swap them later.
Caleb
vanilla gorilla
Old 05-18-2008, 10:16 AM
Black99GST's Avatar
alright! they are EXACTLY the same... infact, they are the same part... just doing some work to my second set i didnt think it would cause an issue, but then again, i wanted to be sure! thank!
