Old 03-05-2003, 01:35 PM
Justin99RS Justin99RS is offline
Send a message via AIM to Justin99RS
CEL 22-98 cav 2.2L
what is it?
1999 Eclipse RS
-Greddy header
-Cold air intake
-Underdrive pulley
-Bored Throttle body
-Apexi catback
-Crane stage 2 cams
-Fidanza cam gears
Old 03-06-2003, 10:29 AM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Are you talking about DTC's?
DTC P0106 Manifold Absolute Pressure (MAP) System Performance
DTC P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
DTC P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
DTC P0112 Intake Air Temperature (IAT) Sensor Circuit Low Voltage
DTC P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
DTC P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
DTC P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
DTC P0121 Throttle Position (TP) Sensor Performance
DTC P0122 Throttle Position (TP) Sensor Circuit Low Voltage
DTC P0123 Throttle Position (TP) Sensor Circuit High Voltage
DTC P0125 Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
DTC P0131 O2S Circuit Low Voltage Sensor 1
DTC P0132 O2S Circuit High Voltage Sensor 1
DTC P0133 O2S Slow Response Sensor 1
DTC P0134 O2S Circuit Insufficient Activity Sensor 1
DTC P0137 HO2S Circuit Low Voltage Sensor 2
DTC P0138 HO2S Circuit High Voltage Sensor 2
DTC P0140 HO2S Circuit Insufficient Activity Sensor 2
DTC P0141 HO2S Heater Performance Sensor 2
DTC P0171 Fuel Trim System Lean
DTC P0172 Fuel Trim System Rich
DTC P0200 Injector Control Circuit
DTC P0300 Engine Misfire Detected
DTC P0301 Cylinder 1 Misfire Detected
DTC P0302 Cylinder 2 Misfire Detected
DTC P0303 Cylinder 3 Misfire Detected
DTC P0304 Cylinder 4 Misfire Detected
DTC P0325 Knock Sensor (KS) Circuit
DTC P0335 Crankshaft Position (CKP) Sensor Circuit
DTC P0341 Camshaft Position (CMP) Sensor Performance
DTC P0342 Camshaft Position (CMP) Sensor Circuit Low Voltage
DTC P0401 Exhaust Gas Recirculation (EGR) Flow Insufficient
DTC P0404 Exhaust Gas Recirculation (EGR) Open Position Performance
DTC P0405 Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage
DTC P0420 Catalyst System Low Efficiency
DTC P0440 Evaporative Emission (EVAP) System
DTC P0442 Evaporative Emission (EVAP) System Small Leak Detected
DTC P0446 Evaporative Emission (EVAP) Vent System Performance
DTC P0452 Fuel Tank Pressure Sensor Circuit Low Voltage
DTC P0453 Fuel Tank Pressure Sensor Circuit High Voltage
DTC P0460 Fuel Level Sensor Circuit
DTC P0480 Cooling Fan Relay Control Circuit
DTC P0502 Vehicle Speed Sensor (VSS) Circuit Low Input Manual Trans Only
DTC P0506 Idle Speed Low
DTC P0507 Idle Speed High
DTC P0530 Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit
DTC P0562 System Voltage Low
DTC P0563 System Voltage High
DTC P0601Control Module Read Only Memory (ROM)
DTC P0602 Control Module Not Programmed
DTC P0705 Transmission Range Switch Circuit
DTC P1133 O2S Insufficient Switching Sensor 1
DTC P1171 Fuel System Lean During Acceleration
DTC P1336 Crankshaft Position (CKP) System Variation Not Learned
DTC P1380 Misfire Detected - Rough Road Data Not Available
DTC P1381 Misfire Detected - No Communication with Brake Control Module
DTC P1404 Exhaust Gas Recirculation (EGR) Closed Position Performance
DTC P1441 Evaporative Emission (EVAP) System Flow During Non-Purge
DTC P1621 Control Module Long Term Memory Performance
DTC P1629 Theft Deterrent Fuel Enable Signal Not Received
DTC U1016 Serial Communications Malfunction
