Old 05-16-2008, 05:51 AM
kads kads is offline
rust
i have a 98 z-71 5.7 with 148,600 miles i am starting to see rust under both ext.cab door pannels is there a way to atleast stop this from getting worse, one guy told me only way is to cut out that lower section on each side and replace cost $1200 ouch thanks
Old 05-16-2008, 11:31 AM
xjcamaro89 xjcamaro89 is offline
Re: rust
What i would do with my 93 is i would sand down the spots that were rusting or bubbling, to bare metal, and used a filler call ALL METAL, or something like it, and i cant remember where i got it from, but i would fill the pin holes and such with that all metal and then spray it with a can. But in my case the bottom of my truck was silver and was easily matched to a can of paint and blended in flawlessly, give it a try!
My 2002 Silverado 1500
Old 05-16-2008, 05:25 PM
j cAT j cAT is offline
Re: rust
to stop this from getting worse use a 30wt non detergent oil and brush on the oil inside of the door panels at all seams.....
i live in rust belt and this is my way of preventing any serious rust problems.....in this area...before doing this i would get a product called extend and apply to all rust areas then after 2 days apply a finish coat of paint then after another 2 days give it a hit of the oil....
Old 05-18-2008, 06:21 AM
Re: rust
thanks ,i will give them a try , kevin
Old 06-29-2010, 09:54 AM
MrBill50 MrBill50 is offline
Re: rust
Fillers will work if you have to replace metal, but you'll also need to prep the area to prevent the rust from coming back. Go to WWW.NOMORERUST.COM and check out Captain Lee's Metal Prep and Conditioner and the Master Series Silver Primer. If you give them a call their technical staff will be happy to help you with your rust problem.
Old 06-29-2010, 04:17 PM
jeffholland00 jeffholland00 is offline
Re: rust
thats also my problem. my car started rusting.maybe because, I am living near the sea.
Project Management Academy
Old 06-29-2010, 09:32 PM
Re: rust
I recommend the Master Series Silver Primer because it has been tested to withstand 14,000 hours of salt spray.
http://www.masterseriescoatings.com/index/faqs/
Old 11-06-2010, 06:04 PM
Re: rust
hey guys
I am looking for a second car for sale?I am planning to buy because I want o give it to my little brother for his birthday. even it is rusty?its ok, I will modify it.
