Go Back   Automotive Forums Car Chat > Chevrolet > Cobalt
Old 05-16-2008, 12:37 AM
tyrant1014 tyrant1014 is offline
Front Seat Belts
Need some help with the torx bits that hold the panels and the seat belts together as I have broken two torx bits on them and the belt holders themselves haven't even budged at all.
I need to get the panels off but right now I'm being stopped by the darn seatbelts!
No task too stupid!
Old 05-16-2008, 09:01 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Front Seat Belts
Welcome to AF.
If you can, try to spray a bit of WD-40 or penetrating oil to the back of the bolt, where the exposed threads are, if you can.
Next, are you sure you have the right Torx bit? Some belt bolts use a #50, some use a #55. Get the biggest that will fit.
Next, get a really good quality bit, one with a lifetime warranty.
There are lots of cheap Torx bits out there that simply will not do the job, so get one from a really good retailer, such as Sears, Snap-On, etc. Their bits are more likely to peel the bolt apart before breaking.
