Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 05-15-2008, 08:36 PM
danf1's Avatar
danf1 danf1 is offline
Send a message via AIM to danf1
Angry Gaah friggin B-Joint
okaaay so i'm finally putting my engine back in, i was putting in the axle (if you guys remember i had to take the entire assembly out) and found out i screwed up the threads on my upper balljoint pretty bad.... well .. like two threads.. but it's stonger than the nut that goes in there so it wont rethread. should i get a re-threader or buy a new upper balljoint?
hanes says you cant replace the balljoint alone but aap sells just the upper balljoint.. any idea how to get it out if i have to replace it?
95 mitsu eclipse rs fwd
Old 05-15-2008, 08:56 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Gaah friggin B-Joint
If its not bad I would just try to get something to rethread it. How much is the new balljoint??
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 05-15-2008, 09:10 PM
danf1's Avatar
it's like 30 bucks.. but i dont know how to take it out.. the book says i cant but i know i can.. might need a hammer for this one
Old 05-15-2008, 10:55 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
I'm not sure if you can replace the balljoint alone. If you can it will probably be hard. You will probably have to take a torch to it to heat it up.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
