Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 05-15-2008, 04:41 PM
93siltbird 93siltbird is offline
no gauges working on dig dash
my digital dash does not light up none of the gauges work checked the fuses and bulbs but no luck i really need help with this one help please
Old 05-16-2008, 08:55 AM
Mike8675309's Avatar
Mike8675309 Mike8675309 is offline
Re: no gauges working on dig dash
Is there any sign that you can see it still working? Does it light up at all, say when you go from off to Run during self check? this is a 93 right? There are complete wiring diagrams for this in www.alldatadiy.com. For example, power to the Instrument cluster lamps is on Pin 13 and is a LightBlue with Red stripe wiring. Should be 12v there with key on which is coming from the dimmer on the light switch I believe. Run power also comes in from pin 15 and pin 9 (Purple with Orange Stripe) which is coming from pin 5 and pin 6 (respectively) Looks like there might be a full time battery source (unswitched) as well on Pin 7, Light Green with purple stripe. Grounds are at pin 8, 2, 10.
www.sccoa.com - SuperCoupe Club of America.
Old 05-16-2008, 09:40 PM
97Bird's Avatar
97Bird 97Bird is offline
Check my last post in the Tech Help thread for a place to get repair info including wiring diagrams for free. To get more complete diagrams ask you local library if they have the Mitchell electrical manual for your year car.Be sure the connections are clean and tight and be sure you have a good ground connection. Were you doing anything in the dash like wiring a new radio before the problems began?
The Original 97Bird
Old 05-22-2008, 03:55 PM
i bought a new cluster and it did not work the radio was not working there was not one in it i just pushed one into the hole where the wiring was i am not sure if there was any exposed wires or not i just put a new stereo in and it works fine the memory fuse is fine in the engine compartment i am baffled any ideas will be helpful thanks
Old 05-22-2008, 03:58 PM
yesw it is a 93 and no it does not light up at all
Old 05-23-2008, 04:10 PM
i am not getting any power from pins 5 and six any ideas
Old 05-23-2008, 07:43 PM
The wiring diagrams are quite complex. Again, the link from 97 bird does not have the diagrams for this. I suggest signing up for the 19.99 alldata deal. they have complete wiring diagrams for this, though they are very complex. The Dash receives power from the secondary junction box. This is a box located under the dash to the right of the steering column. On the panel, check for power at 15 and 9 with the key on. Should be purple with orange stripe. Batt power appears to be at pin 7. Purple light green with purple stripe. Check for power there first. Then you can start working your way back to find it. (make sure there are no blown fuses for the fuse block under the dash, nor any fuses in the power distribution block under the hood)
Old 05-24-2008, 08:54 PM
97Bird's Avatar
Wiring diagrams in the Mitchell manual at your library are complete and free to look at or not much money if you want to photocopy them! If you can get me the diagrams I will walk you through the steps to find the problem. I only have diagrams for a '97.
The Original 97Bird
Old 05-24-2008, 09:17 PM
i ckecked all the power to the cluster and all the power are good i bought a used cluster and still no luck any ideas
Old 05-26-2008, 12:27 AM
the cluster works but you can only see it when it is real sunny out
Old 05-27-2008, 02:36 PM
Well, then that's a different story. You should get the wiring diagrams so you can see what you have to work with. Typically when the display works but no illumination, that means a swap out and send it to the manufacturer for repair. They are not user or shop serviceable. There are a couple feeds for the instrument lights, but not sure what they do. Oh, and make sure you don't have the dimmer turned all the way down, effectively shutting down the panel.
