Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 05-15-2008, 04:37 PM
lmdittrich lmdittrich is offline
Injector Noise
My engine clicks loudly on cold start for about 30 seconds and then quiets down. I was told it was injector noise and was fine as long as it stopped, but it is really loud. Is this something I should worry about or have checked?
Old 05-21-2008, 10:09 PM
Davescort97 Davescort97 is offline
Escort guy
Re: Injector Noise
Welcome to AF. That noise you describe wouldn't be injectors. They do make noise but not to the extent of your problem. I would suggest that the lifters aren't pumping up until the engine has run for a while. If you live in a cold climate they will talk to you until the engine has run for a while. I would suggest changing to a lighter oil that will pump the lifters up faster. Change the oil and go to a 5w-30w weight.
Old 05-22-2008, 10:30 PM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Re: Injector Noise
factory oil is supposed to be 5W-20...
