Old 05-15-2008, 03:37 PM
raymarquise raymarquise is offline
Battery discharge lamp
94 voyager, 3.0L
My battery died today and I can't tell for sure if it is the battery or the alternator not charging. When I switch on the ignition with the engine off, there is no battery discharge lamp lit, so how do I know if the alternator is charging when the engine is running?? Shouldn't there be a discharge lamp lit with the ignition on, engine off??
Old 05-15-2008, 06:42 PM
Bear Bear is offline
Re: Battery discharge lamp
Start her up and then put a volt meter on the battery posts (+to+ and - to -), set scale at 15 volt DC and you should read about 14.0 Volts DC if the alternator is working good, if less than 11.0 VDC I would suspect the alternator.
Old 05-16-2008, 08:32 AM
Followed your advice and the alternator checks out OK at 14.1 Volts. Still, shouldn't I see a battery discharge lamp illuminated on the dash with the ignition on, engine off??
Thanks.
Old 05-16-2008, 09:39 AM
jpb53 jpb53 is offline
Yes all warning ind lamps should illuminate at key on. Probably a burned out bulb.
Old 05-16-2008, 04:07 PM
OK, I finally did see the battery lamp. when I switch the ignition on, it flashes on for one second then goes off. Why wouldn't it stay on with the engine not running???
