Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 05-15-2008, 02:20 PM
mcdodo mcdodo is offline
starter
having trouble removing starter bolts heads of bolts are rounded can they be cut of or any ideas 1992 yj 2.5 litre
Old 05-15-2008, 08:25 PM
soldierp89's Avatar
soldierp89 soldierp89 is offline
Re: starter
you could try hammering a smaller size socket on it, or you can get sum vice grips on it if possible. i dont know what the bolts look like. if you can, try to cut them off. i had the same problem with my wheel bearing bolts. i got two off, but the 3rd one was stipped so bad i just welded a crappy socket to it. i have also heard of using a file to "trim" the bolt so you can get a socket on it.
89' YJ / 95' YJ / 94' XJ
4.2 L I6 / 2.5 L I4 / 4.0 L I6 HO
5 Spd. AX 15 / 5 Spd. AX 5 / AW4 3 Spd. W/ OD
4" Rough Country / 4" Pro Comp
Mickey Thompson 33/11.50/R16
BFG Mud Terrain 33/12.50/R15
Old 05-16-2008, 08:07 AM
tomvid tomvid is offline
Re: starter
These work great for stripped or sheered bolts.
http://www.sears.com/shc/s/p_10153_1...0P?vName=Tools
97 Jeep Wrangler SE 2.5L
Things I've repaired:
Thermostat: Crankshaft Position Sensor: Radiator: Water Pump: Fan Clutch: Wires: Dist Rotor: Dist Cap: Plugs: Disc Rotor: Pads: Sway/Stabalizer bar links: Axle Shaft U-Joints : Transmission swap : Brake line : Shocks : Rear Pinion Seal : Transmission Mount
