Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 05-14-2008, 06:37 PM
hotrod1459 hotrod1459 is offline
problem after install header
i have a 96 sunfire 2.4 i installed a header now when the car sits it will start fine but when i go it will hesitate and fluter for couple of seconds then it ok until i shut it off and let it sit again.
im lost on this one
ps it is a standard and i already cleaned the throddle body
Old 05-29-2008, 01:03 AM
demo_deven's Avatar
demo_deven demo_deven is offline
Send a message via MSN to demo_deven
Re: problem after install header
When you replaced the header, did you also replace the O2 sensor? A faulty O2 sensor can throw the computer off and make the car run rough. I'd definatly replace that if not already done so.
"If it runs and moves, DERBY THE DAMN THING!"
- 2000 Ford F-150 4.2L V6 Reg. Cab Long Box 223k. Nothing special, just a beater work truck.
- 1995 Ford F-250 7.3L PSD 2WD 291k. K&N Air Intake, 4" Turbo-Back to 5" Staks through the box. Other then that a good truck for pulling around my toys!
www.SmashCarRacing.com
1997 Pontiac Sunfire
Old 05-29-2008, 12:14 PM
when i bought the car it had a new o2 sencer in the glove box, so i put that in with the new header. but maybe ill try a nother one, there not that much money. as far as derbying it. it a convertible. and i dont derby anymore.
but if derby is your thing here is what i used and last 15 1/2 derbys.
get an old monte carlo or grand prix around 1975 with a good frame(hard to find) if the engine runs use it until it goes. but then put in a v6 early 80 cars. at time there was no oil or water and the thing just wouldnt die.
a couple mods and some weilding and your set.
