Old 05-14-2008, 04:15 PM
1deserteagle 1deserteagle is offline
Exclamation Right front click, LOUD whine, clunk
Hi, I just want to thank Automotive forum and it's members. I found AF on Google after enteriing my problem on the search engine. After reading several threads with similar problems I was able to bypass much expensive trial and error experianced by other members and fix the problem for $15. My 1993 s10 Blazer would start clicking from the right front when going down the road then if I let off of the gas it would make a very loud whine until I slowed to an almost stop then it would clunk and stop. It might not do it again for a day, or it might do it again within 5 mi. It only did it in 2WD and I found that I could stop it without the painful whine and clunk by bumping it into hi 4WD and then out again. I figured that it was trying to partially engauge the front end but couldn't figure out why. Turns out that it was a $15 transfer case switch located on top of the transfer case. It is a vacuum switch with 3 vaccuum lines that plug into the top. The switch has a check ball that can stick. In my case it stuck open and was feeding the actuator just enough vacuum to partially engage the right hub. Five minutes, a 7/8 wrench and a couple skinned knuckles (it's tight) and the problem is solved. I sure am glad that I found AF. It just saved me hundreds of dollars in trial and error.
Thanks to All
Dan
Old 05-15-2008, 08:12 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Right front click, LOUD whine, clunk
Welcome to AF
And you are welcome for the Thanks.
Smart move by searching the forum to find you problem.
Glad all is well and fixed.
Thanks por posting and letting us know how it went.
And if you do not find your problems doing a search you are welcome to start a New thread/post and there will be people to help you .
Good Luck
MT
MT
