Go Back   Automotive Forums Car Chat > Buick > Roadmaster
Old 05-14-2008, 12:47 PM
agjones agjones is offline
92 buick rm rear shocks
when i have a load in my car it levels okay when you get in but as you drive it goes down in the back . but when you stop and park it pumps up okay . with no load no problem it stays up ; any Idea what could be the problem. thanks Allen
Old 05-15-2008, 10:33 PM
bocoogto bocoogto is offline
Re: 92 buick rm rear shocks
I believe this is caused by an air leak between the compressor and the shocks. Isn't there a logic system that only allows so much run time before the compressor stops? If not for this logic system, the battery would go dead when the car is not running, but leaking air in the leveling system.
Need help from someone more familiar with the system.
Old 05-16-2008, 12:29 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Sounds like a leak to me somewheres also. I had a similar system in my Venture, ( but not in my Roadmaster.) The system developed a leak and the compressor would go on when the level got too low, and then stop once the proper level was achieved. This occurred whether the van was running or not, (scared a few people in parking lots as they walked by the van as the compressor went on with it's "growling" noise.) I eventually pulled the fuse to the compressor. It never really drained my battery, perhaps because either the vehicle was used everyday and didn't have the chance to fully discharge the battery, or the leak was so minor and the compressor not operating that much to drain the battery, and the battery being in good condition and able to withstand the minor draw from the compressor.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
