Old 05-14-2008, 09:48 AM
Pimpdady753 Pimpdady753 is offline
rear gears
so i went and got quotes on getting my rear gears swapped out for a set of 4.10s and every one wants at least 1,000 dollers. Does that seam high to u guys or what. ive got a 86 gt with the stock rear end. thanks
Old 05-14-2008, 01:44 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: rear gears
Thats over double what it costs around here.
1969 Cougar
357w & TKO - 475hp
Old 05-14-2008, 04:57 PM
Re: rear gears
yeah thats what i thought, there is no way im paying some one 1,000 just to put in rear gears. how hard is it to do your self, if u get like the rear gear kit install from summit or somthing.
Old 05-16-2008, 03:13 AM
351wStang's Avatar
Re: rear gears
Its easy after you've done it. Just take your time with it. But there is alot more to it than just bolting it together.
1969 Cougar
357w & TKO - 475hp
Old 05-18-2008, 08:20 PM
giddyup50 giddyup50 is offline
Re: rear gears
Exactly!!! I've never done it, never will. Unless you have someone who's done it many times before showing you how, I would not attempt it. Too many things to go wrong. Kind of like the trans. Not as complicated ofcourse but, just alot that could go wrong if you don't know what you're doing.
$1,000 is WAY TOO MUCH for that. Should be in the ballpark of $500. Call around and check.
I know you said you had an 86 so, that means you have the 7.5 rearend. Unless it's been changed. I would spend the money on getting an 8.8 from an 87-93, then get new gears.
Old 05-19-2008, 01:48 AM
Re: rear gears
did the 86s come with the 7.5, i thought it was the 8.8 rear end
Old 05-20-2008, 09:31 AM
b3warnick b3warnick is offline
Re: rear gears
$1,000 is way too high...I've had 'em done for $500 and $600. Shop around and find someone that knows what they're doin. And if you know a good mechanic, but he wants a couple extra bucks...do it. Don't try to scrimp too much---I know---had 4.10's put in my Mach1 and saved a buck or two over my regular mechanic --- big mistake. Guess what...my regular mechanic had to fix what the first guy f----- up. Tolerances were all wrong, wrong spacers.... it was a mess. Ended up paying twice for what I shoulda had done right the first time.
Old 05-20-2008, 06:01 PM
Re: rear gears
Yeah, you may be right. Maybe they started in 85 w/the 8.8 rear. Call a couple Ford dealers parts dept. and check. I could of swore it was 87 though.
Old 05-25-2008, 12:57 PM
Muscletang's Avatar
Muscletang Muscletang is offline
AF Premium User
I had an '86 GT and for me it was $200 for the gears and $200 for the instal for a grand total of $400. Doing it for $1000 is WAY to damn much.
For a long time it gave me nightmares... witnessing an injustice like that... it's a constant reminder of just how unfair this world can be... I can still hear them taunting him.......
silly rabbit, tricks are for kids...
I mean, WHY COULDN'T THEY JUST GIVE HIM SOME CEREAL?
Originally Posted by Lars Ulrich
What?! Record sales are slumping? Must be from all those pirates. Can't be because we started sucking 10 years ago.
Old 06-02-2008, 10:39 AM
dan89 dan89 is offline
Re: rear gears
for a grand, you might as well go to the stealership
click for my cardomain ^
Old 06-28-2008, 06:41 PM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
Re: rear gears
That's way too high, I typically charge $300 for install plus parts.
My ride at my site Silverstangs.
Old 10-22-2008, 10:04 AM
mstng46 mstng46 is offline
Re: rear gears
1000? that's gotta be with the parts included...you'll spend about 320 for the gears and bearing kit and you'll have to pay for carrier shims which will prolly be around 35 so your looking at $355 on parts, labor is probably going to be around 5 hrs. I don't know where your located but a dealership will prolly be 100/hr...so your looking at $855 + tax....yeah 1000 is a little high...I wouldn't take it to them...they probably don't want to do it so the jacked the price hoping that you wouldn't go through with it...most likely they aren't capable of doing it either....and no don't go out and do it your self because you def. don't have the right tools for the job...and the 86 had the option of either a 7.5 or an 8.8....shop around a little bit before you commit anywhere and make sure what rearend you have before anything...have you thought about swapping in a new diff? go posi for sure limited slip is junk...
