Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 05-13-2008, 10:22 PM
dennis84 dennis84 is offline
Check engine light
Can anyone explain check engine light code p1507 for a 2000 Ford Explorer 5.0 engine?
Old 05-13-2008, 11:09 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Check engine light
Welcome to the forum!
Per the factory service manual:
P1507 - Idle Air Control (IAC) Underspeed Error
This DTC is set when the PCM detects engine idle speed that is less than the desired rpm.
Possible causes:
  • IAC circuit open
  • IAC circuit short to PWR
  • VPWR to IAC solenoid open
  • Air inlet is plugged
  • Damaged IAC solenoid
  • Damaged PCM.
-Rod
Old 12-05-2009, 06:27 PM
primozaj primozaj is offline
I have the same code on a 1998 Mercury Mystique (Ford Contour). Bought an IAC at autozone and will be replacing it tomorrow. If that doesn't work, any other ideas? BTW, all the input on here helped me decide what to do... thanks!!!
Old 12-11-2009, 07:25 PM
shorod's Avatar
SHO No Mo
So did replacing the IAC make a difference? What symptoms, if any, are you experiencing? Also, which engine does you Mystique have?
-Rod
