Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 05-13-2008, 09:28 PM
jveik jveik is offline
partially-full radiator
my coolant has been dissapearing. i noticed however that if i let it get maybe 2 or 3 inches down from the radiator cap opening when it is cold, it will maintain that level and i dont have to add coolant. could the culprit be a leaky hose to the overflow reservoir or a cracked reservoir? i am worried that perhaps if i let it stay low in the radiator that the top portion of the inside of the radiator above the water might corrode? i wouldnt think it would since the outside surfaces don't and i figure the inside is the same material as the outside, but does anyone know of oxidation occuring due to this?
Old 05-13-2008, 09:44 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
Re: partially-full radiator
well what kind of vehicle are we talking here ?
and does it have a radiator fluid recovery tank ?
if not then it is normal to have air space about 2 inches from the top of the radiator when it is cooled off
water expands when it is hot
it is impossible to keep the radiator full when it has cooled off, the water shrinks
this is how it always was in the years before coolant recovery tanks
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 05-13-2008, 10:02 PM
Will Help Will Help is offline
Randy78 is correct. Cars without recovery tanks will be low when cold.
However, if you have a closed system recovery tank it is not good that your system is low when cold. This can allow air into the system and cause cavitation on the top side of the engine. That is why the closed system recovery tank was invented. It allows for expansion of the fluids and then sucks them back in as the engine cools thus keeping it full with no air cavitation.
If you have the closed system, you could have a leaky recovery tank, bad radiator cap, bad return hose OR another leak in the engine somewhere that is sucking air back in ahead of the cap or leaking coolant and creating it's own water shortage.
Old 05-14-2008, 10:15 PM
well, i dont think i have to worry about air in the intake, since it's a 4.3 in a full-size pickup truck, so even though it's low, the level in the radiator is still higher than the motor. i figured it was ok, since i have seen many cars that just have a tube that dumps overflow on the ground, so the cold coolant level in those cars naturally would be a few inches lower than the top of the radiator
