Old 05-13-2008, 09:20 PM
JoefromPA JoefromPA is offline
fuel pump issues
I Can Not Get Any Power To Fuel Pump,only Power In Harness Is One Wire (purple) Which I Am Assuming Is For Fuel Gauge.i Have Checked Fuse In Box And Relay Under Hood,all Look Good.is There Something Else I Need To Look At???
Old 05-13-2008, 10:05 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
Re: fuel pump issues
ok well the fuel guage has nothing at all to do with the fuel pump
so forget that
make sure that you swap the FP relay with another one to rule it out as being bad
it will click when you first turn the key switch all the way on to run position, and then click off after about 3 seconds
one wire/spade of the FP relay socket will be hot with key on
make sure one is
if not then theres a problem either a melted fuseable link at the starter, or somewhere else
check all connectors in the key on hot circuits for a melted spade connector
for example i had no power to the FP relay or headlights in a 94 astro van i was working on
and i could not find anything bad anywhere
until i pulled the fuseable link wires block off the firewall and separated the bolted together connector and found that one of the fueseable link spade slots was melted burnt badly
it happened ot be the link that supplied power to the headlights and to the FP relay circuit
i bypassed it and all was fine after that
the wierdest things sometimes
i dontknow what exact issue you have though ?
are you sure exactly what and where is getting or not getting power ?
and at what times/what key position ?
the relay will kick the pump on for about 3 seconds when you put the key switch into run position and then it will kick off
whe you crank and start the car then the relay is no longer in use and instead the oil pressure switch takes over
anytime the oil pressure falls below a preset PSI then it will cut off power to the FP
if its faulty then the car wil start but then die in about 3 seconds everytime
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 05-13-2008, 10:11 PM
Will Help Will Help is offline
Yes, and not an easy task. The connectors at the fuel pump ( on top of the fuel tank ) can corrode and cut the power to the pump.
I don't have a manual on your vehicle but some cars have an access panel under the back seat or in the trunk that allows you to check this, otherwise you have to drop the tank.
Someone else may have another possibility that could be a cure to your problem. So give this a day or two, if you can, before you have to pull the tank.
Old 05-14-2008, 04:28 PM
I Know Only The Purple Wire In Harness Is Getting Power Back To Tank.there Is A Grey Wire In Harness When I Supply Power To It Through A Jumper Fuel Pump Runs.i Have Changed The Fp Relay With A New One.the Wires On Top Of Tank Being Corroded Doesn't Make Any Sense To Me Not Sending Power To Pump.i Currently Have Harness Disconnected Just Before Tank,sothere Shouldn't Be Any Way There Could Be Any Kind Of Feed Back???i Never Considered A Fusible Link
