Old 05-13-2008, 07:16 PM
jgeorg jgeorg is offline
Actuator
How can I get to the climate control actuator on an 02 without breaking too many clips, etc....
Old 05-16-2008, 06:38 AM
polarzak polarzak is offline
Re: Actuator
Assuming to 02 is the same as my 00, I do not recall there were any clips. Just remove the panel in the passenger foot well. Oh, and by actuator, again I am assuming you mean the vacuum motor that opens and closes the heat door.
Old 05-17-2008, 08:12 AM
Re: Actuator
You assumed right on all counts polarzak. I found it. It did show movement when connected. I opened it and the gears are not cracked. I'm not sure what else to check for.
Old 05-17-2008, 08:47 AM
Re: Actuator
Is there a drivers side actuator to control heating and cooling and if so where and how might I get to it?
Old 05-30-2008, 06:08 PM
Re: Actuator
I got to the drivers side vent actuator and it's done. No moment and harness has power. Does anyone know of a cheap online source for a new one? The original part # was 16164972 but has been superseded by number 89018375.
Jerry
Old 05-30-2008, 09:34 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Actuator
Enter the part number in the search block on either of the following sites and the part will come up.
GM Parts Direct Alternate Catalog
RockAuto Parts Catalog
