Old 05-13-2008, 02:20 PM
chazmanjr1 chazmanjr1 is offline
ecm location
hi all im back i have a 87 chevy s-10 blazer 4x4. does anyone know where specificly the ecm is located and if they can be checked. i got the timing straight but im getting no fuel out of the injecters. also my check engine soon light is coming on sometime when i turn the key on but sometimes it is not. i mean when i just turn the key on not while i am trying to start it. it is a 2.8 liter. she wants to start now but wont get fuel through the injecters but fuel is getting to the throttle body. u guys r great plz help me. thx chaz
Old 05-13-2008, 05:47 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: ecm location
Under right side of dash board.
Pull glove box and see if you can see it.
Check for proper fuel pressure.
The injector and ECM has fuses.
Check all fuses.
Check for good hot blue spark and injector pulse.
Also pull codes and post back code no.
Will it start on a shot of carb cleaner?
MT
Old 05-13-2008, 09:34 PM
Re: ecm location
yes it wants to start on starting fluid.thx chaz
Old 05-13-2008, 09:36 PM
Re: ecm location
actually it runs for a few seconds.
Old 05-14-2008, 09:21 AM
MT-2500's Avatar
AF - Advisor
Re: ecm location
No starting fluid please.
Just carb cleaner.
Check fuel pressure and for good spark.
And check codes.
Post back what you have.
MT
MT
Old 05-14-2008, 05:25 PM
Re: ecm location
thx mt how do i do the paper clip trick to get the codes? why no starting fluid? what two spots on the ecm plug? thx chaz
Old 05-14-2008, 05:59 PM
MT-2500's Avatar
AF - Advisor
Re: ecm location
Jumper pins A and B on diagnostic connector.
Starter fluid has been known to blow off the valve covers and oil pan off and put the oil fill cap threw the hood.
And will give you a shave and a hair cut with eye brow trim if your head is close when it blows.
Use at your own risk.
MT
MT
Old 05-15-2008, 06:30 AM
Re: ecm location
mt is that the 2 upper right pins for the diagnostic codes? thx chaz
Old 05-15-2008, 08:05 AM
MT-2500's Avatar
AF - Advisor
Re: ecm location
http://www.troublecodes.net/GM/
Have you checked all uses?
Some of them have a fuel pump fuse by relay on firewall to.
MT
Old 05-15-2008, 11:36 AM
Re: ecm location
i will check but r the 2 used to check the codes in the upper right hand corner? thx
Old 05-15-2008, 12:21 PM
MT-2500's Avatar
AF - Advisor
Re: ecm location
Look at the picture posted.
Upper right pins A & B.
MT
MT
