Old 05-13-2008, 09:51 AM
Lucianp Lucianp is offline
rear a/c windstar 2000
Hi everyone. I'm new to the site. I'm not a mechanic but I don't mind getting my hands dirty if I know what I'm doing.
I will probably have several threads going as I have lots of probs with my 2000 Ford Windstar
My first problem is the rear cabin A/C does not work. Neither the air or the fan is working. When I try to select it either from the front control or the rear control panel, I hear a clicking noise at the back of the van.
Is this a relay? and would this be the cause of my problems?
How do I go about testing and replacing?
Any and all help is much appreciated.
I also have a similar problem with my driver window not opening. Same clicking noise, but from the door. If the two are not related and do not share a common point I will address the door in a separate thread.
Thanks in advance.
Old 05-13-2008, 02:17 PM
Re: rear a/c windstar 2000
Does anyone know about a/c??
Any help will be a great help.
thanks.
Old 05-13-2008, 03:51 PM
12Ounce 12Ounce is offline
The system is a bit difficult to explain. If the front ac is working, then the refrigerant is being pumped/compressed ... one ac compressor for both the front and back. Under the inner LH rear plastic quarter panel is a lot of "stuff": One heater coil, One cooling (expansion) ac coil, One temp electric blend-door actuator, One mode (up/down direction) vent electric blend-door actuator, Two fan speed selection relays, and One motor speed resistor assembly.
But before you open that up ... make sure the fuse #117 at the battery is OK, as well as fuse #23 and "aux blower relay" near your left foot are OK. (Just because a relay may "click" or move ... doesn't mean its working.) These fuses and relay are all that should be necessary to make the fan run single speed ... unless the resistor assembly is broken.
Old 05-13-2008, 06:56 PM
thanks for the reply 12Ounce.
this is ok. I also checked all other fuses in this location
fuse #23 is ok. there are 6 relays marked as Relay 1 -Relay 6. There is no indication as to which relay does what.
How do I know which relay to check?
How do I check relays?
I need to figure out how to get into this. The grill at first glance looks like it should come off but when I tried, I think it's actually it's part of the inside panel. Do I remove the whole panel?
really do appreciate the help.
thanks
Old 05-14-2008, 07:51 AM
Does anyone know how to remove the inner LH rear plastic quarter panel ?
The manual shows the grill panel removed but on my van it appears as if the panel is part of the interior.
I've tried getting a thin blade in behind it but there doesn't seem to be a split to get into. I ran a blade round where I thought the split should be in case it was covered with hardened polish or something. No luck.
There's got to be an easy way to get this panel off without scratching the interior any more than I already have.
Any suggestions???
Thanks
Old 05-14-2008, 08:38 AM
#3 is for the front blower. #6 is for the rear blower. JUST THIS ONCE ... swap the two. (BTW, if you have the glove box manual .. this should be covered there.)
The whole panel has to come off. The grill is molded in, I believe.
Old 05-14-2008, 09:59 AM
Thumbs up Re: rear a/c windstar 2000
12Ounce, you've cracked it.
I swapped them over and the rear A/C works. Man, I'm glad I didn't need to take that panel off. Now I need to go and buy a replacement.
No, I don't have a glovebox book. Unfortunately. If all this info is in the user handbook, it's a pity it's not in the Haynes.
Thanks 12Ounce. I appreciate your help.
Now for a new thread on my driver door window. Perhaps that's a relay too! Fingers crossed.
Old 05-14-2008, 11:37 AM
mundy5 mundy5 is offline
hey hey Lucianp, that's great news! that's a very helpful tip 12Ounce. I didn't realize that the relays were interchangeable. I need to keep that for my own records for the future.
2003 Windstar LX
1998 4dr Civic LX
Old 05-14-2008, 12:14 PM
So I'm not the only guy who has bad relays!!! (Actually my knees are not so good either ... or my eyes ... or my ears ...etc,etc ...LOL!)
BTW, if you pry up the button control panel on the drivers door, open up the switch assembly ... clean and lubricate all the little switch contacts (tedious work) ... you'll probably be OK. If not, you may need a regulator-motor.
Old 05-14-2008, 06:12 PM
Selectron Selectron is offline
Hi, you can download a free copy of the glove box manual in PDF format from this Ford site. It will have diagrams for the fuse and relay layouts, and a list of the functions of each.
