Old 05-12-2008, 11:50 PM
Eagle70ss Eagle70ss is offline
Rear Diff problems/leak?
So, I noticed there was a drop of diff fluid on the bottom side of the case and so I investigated. I drained the fluid and noticed that the diff was no longer full. The only place the was wet was around the upper fill plug and the stream that it left on the way down. The yoke seal was completely dry all the way around...I was perplexed about how fluid could be coming from the fill plug. Anyways I filled the diff back up and tightened both plugs really snuggly. I noticed after I drove it, it was doing the same thing. I cleaned the diff and put silicon around the rim of each plug and now there is no more leak. Any ideas?
Old 05-13-2008, 05:40 PM
j cAT j cAT is offline
Re: Rear Diff problems/leak?
the diff plugs need thread cleaning wire brush if necessary and a coating of thread sealant... not silicone sealant...use a degreaser to clean oil off threads before applying thread sealant.. i believe 15ft lbs of torque to tighten....
if this diff operated with a low fluid level removal of diff cover to inspect and clean cover magnet....if no magnet get one....
Old 05-13-2008, 11:03 PM
randy78 randy78 is offline
Send a message via Yahoo to randy78 Send a message via Skype™ to randy78
the plug uses plumbing threads and self seals due to the thread shape
silicone is bad
but youre only sealing against gravitiy anyways
so even bubble gum would work fine
plumbers pipe thread dope is what i use on almost any threads, including head bolts threads
it lubes and seals, to 500 degrees, and higher PSI
perfect stuff
axle oil leaks, it happens
and most ppl never check the axles and let them leak dry and go kaboom
good luck
I also am user fastr68 here- Randy
-'54 F100 302 C-6 -'57 F100 -'57 Bel Air HT 307 4spd '57 210 HT 4dr 265 3spd -'68 corvair monza convertible w/ PG -'79 C-20 -'80 K-20 -'82 K-10 SS -'82 TRANS AM WS7 HT 5.0L TH350 2400 stall blue/blue level III PMD cloth PG hood -'85 Elky SS 310ci 2004r fully restored 2008 -'88 buick century estate wagon 3800 4t40e, 91 s-10 2wd 4.3L, 96 taurus, '97 cavalier RS 2.2L, 5sd -'05 18ft car trailer, 98 achieva, 98 cherokee,
Old 05-14-2008, 09:43 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
And always check the rear axle vent and vent line for beinging pluged.
No vent will stir up leaks in it.
MT
MT
Old 05-16-2008, 04:21 PM
Vent line? I have a vent hole that's almost directly above my fill plug(maybe a 1/4" through hole or so)...There's nothing obstructing that hole. Is that all I need to check? Anyhow I ended up changing the yoke seal and that seems to have cured the problem.
randy:
Do I get that plumbers dope and hope depot or other hardware store?
Old 05-16-2008, 04:33 PM
randy:
you need a vent line installed,since you don't have a clue on this as it was originally go to a used car lot and look under trucks there then buy what you need to reconstruct this vent line with a piece of plastic stuck on the end of hose...if you don't you could end up with water and other contaninates and leaks from/because of that hole not properly vented...
home depot or a auto parts store will have thread sealant tell them it's for the diff fill/drain plugs.....
i use permatex thread sealant.....
