Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 05-12-2008, 10:32 PM
Brian Beverage Brian Beverage is offline
97 gcl not shifting to overdrive
Guys and gals im stumped. I think that either my transmission has finally started to go or im losing something else. It strated to idle real fst the other day toabout 2k then if it sat it would go higher, well on the way home from work it wouldnt shift into overdrive either. it shifts fine through the other gears. But we unplugged the battery and i think that reset the MAP sensor or whatever. But still no OD. up to 170000 miles now. help please....
1997 Jeep Grand Cherokee Limited
Full Time Quadra Trac
4.0 InLine 6
178,000 Miles
Old 05-13-2008, 07:56 AM
HanibalTheCannibal's Avatar
HanibalTheCannibal HanibalTheCannibal is offline
Re: 97 gcl not shifting to overdrive
sounds like a vacuum leak is throwing everything off. The OD will not engage if it detects low vacuum. The engineloses vacuum under acceleration and the OD is set to NOT shift when under load.
I would look for hissing sounds under hood. I know its hard when engine is running. You may have a vacuum hose that came off by the tranny. Check there.
2001 5.3 LS Stock
6 channel Alpine 3566 Amp
Jason Extreme Slam Camper Shell
Michellin X-Radials
79K Miles
Old 05-13-2008, 12:42 PM
reekor reekor is offline
A vacuum hose that came off by the tranny?
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 05-13-2008, 12:45 PM
Have it checked for engine codes, see if anything comes up. If not have your TPS tested.
Old 05-13-2008, 05:20 PM
A vacuum hose that came off anywhere, probably a large one from the sound of it.
2001 5.3 LS Stock
Michellin X-Radials
79K Miles
Old 05-13-2008, 07:21 PM
I just had to ask since the 97 transmissions are not vacuum controlled.
Old 05-16-2008, 11:16 AM
Ok um I cant find a vacuum hose so that would make sense. I have no check engine light or anything, (Other than the notorious "Coolant Sensor Bad" and Rear Lamp Failure" on the VIC. It could be the TPS you think? Im at a loss.
4.0 InLine 6
178,000 Miles
Old 05-16-2008, 01:49 PM
There is a good chance your TPS has at bad spot at closed throttle. Did you check for vacuum leaks between the intake and head? You don't need to have a check engine light on to have a stored code, even more so for a transmission code.
Not much that can be done about the Coolant Sensor other then replacement. 80% of the time the Rear Lamp Failure is due to a burnt out bulb in the over head brake light (3 bulbs). the other 20% is a mix between a bad bulb combo and people burning out the lamp module with poor trailer wiring.
