Go Back   Automotive Forums Car Chat > Mercury > Mystique
Old 05-12-2008, 10:38 PM
jeremy06 jeremy06 is offline
Send a message via Yahoo to jeremy06
location? LQQK Please help
coolant temp sensor
intake temp sensor
mass airflow sensor
idle air control sensor
throttle position sensor
please be describtive thanks for any help
Old 05-13-2008, 08:59 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Re: location? LQQK Please help
Originally Posted by jeremy06
coolant temp sensor
intake temp sensor
mass airflow sensor
Please be more descriptive in the engine that you have.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 05-14-2008, 09:26 PM
2.0
Old 05-15-2008, 05:22 PM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
what year
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 05-15-2008, 07:30 PM
Thumbs down Re: location? LQQK Please help
I have a 1995 Mercury Mystique 2.0 zetech, automatic trans. My temp gauge doesn't work? Also I don't know how to remove the window motors from the doors because of the cables that go into them.
I different question, On the doors are the speaker grills, are they removalable? if yes how?
Old 05-16-2008, 02:56 PM
pre98zetec's Avatar
Coolant temp is on the right side of the motor (looking straight on at it, not from driver seat), It's directly on top of the thermostat housing, right in front of the coil pack.
IAT is on the tube in between the MAF and the first intake resonator.
the MAF is right after the airbox.
the IAC is a hard one, its located behind the motor, its really a pain in the ass to explain let alone remove.
speaker grills are removable, but they're melted into the door panela nd require you to remove the panel and cut the studs melted.
Check out www.contour.org forums for more help
-Josh-
